Audirvana Plus License Problem
Audirvana Plus lost its license information, it is asking for the license key, however only have a license file.
I tried reinstalling but it keeps asking for the license key and there is no option to use the license file.
I there a work around for this?
Thanks,
Wouter
Your license file you purchased some time ago is meant to be used with the version 2 of Audirvana Plus.
You can redownload the version 2 program if needed at https://audirvana.com/delivery/AudirvanaPlus_2.6.8.dmg
To get your version 3 license key, you’ll have the opportunity to purchase it at a reduced upgrade price on audirvana.com.
In the meantime you can use Audirvana Plus 3 by requesting the 15 days trial license.
