Hi, Audirvana does not work well with Marantz PM7000N.
I can’t use any plug-in while playing a music, simply dont’t show the plug-in popup. Furthermore, the musics are cut before the end of the track. May be some bug.
I don’t understand why these things happen!
Hello @duchuchebu,
For the plugin you won’t be able to view them while you are using UPnP, you will need to change the settings of the plugin before playing your track.
Can you send me a copy of the “Debug Info” while you have your PM selected in Audirvana? You can get it in Audirvana Settings>General>Debug Info
Audirvana 3.5.45
Max allowed volume: 87.3784
SW volume control: ON
Sync list: 0 folders
Library database path: C:\Users\Audirvana\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Preferred device: Marantz PM7000N Model UID:Marantz Marantz PM7000N UID:uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6
UPnP device at http://192.168.0.2:60006/upnp/desc/aios_device/aios_device.xml
Marantz PM7000N Manufacturer:Marantz
Volume control: No
http-get::audio/mpeg:
http-get::audio/x-ms-wma:
http-get::audio/L16;rate=48000;channels=2:
http-get::audio/L16;rate=48000;channels=1:
http-get::audio/L16;rate=44100;channels=2:
http-get::audio/L16;rate=44100;channels=1:
http-get::audio/wav:
http-get::audio/mp3:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
CurrentTransportStatus: ERROR_OCCURRED
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI: http://192.168.0.14:49152/audirvana/audio_1_5.mqa.wav
CurrentURIMetadata: dc:titleQue Bonito Es Vivir</dc:title>http://192.168.0.14:49152/audirvana/audio_1_5.mqa.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorIl Divo</dc:creator>upnp:genre""</upnp:genre>upnp:artistIl Divo</upnp:artist>upnp:albumTimeless</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/dd25186d/94d5/4b09/ab3d/2289fb0f72bb/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber7</upnp:originalTrackNumber>
nextURI: http://192.168.0.14:49152/audirvana/audio_1_4.mqa.wav
nextURIMetadata: dc:titleQue Bonito Es Vivir</dc:title>http://192.168.0.14:49152/audirvana/audio_1_4.mqa.wavupnp:classobject.item.audioItem.musicTrack</upnp:class>dc:creatorIl Divo</dc:creator>upnp:genre""</upnp:genre>upnp:artistIl Divo</upnp:artist>upnp:albumTimeless</upnp:album>upnp:albumArtURIhttp://resources.tidal.com/images/dd25186d/94d5/4b09/ab3d/2289fb0f72bb/640x640.jpg</upnp:albumArtURI>upnp:originalTrackNumber7</upnp:originalTrackNumber>
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 GetCurrentState CurrentState out LastChange GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Next InstanceID in A_ARG_TYPE_InstanceID Pause InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Previous InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID X_SetShuffle InstanceID in A_ARG_TYPE_InstanceID Shuffle in X_Shuffle AVTransportURI string AVTransportURIMetaData string A_ARG_TYPE_CurrentState_AVTransport string A_ARG_TYPE_InstanceID ui4 A_ARG_TYPE_ObjectID string A_ARG_TYPE_SeekMode string TRACK_NR TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string AbsoluteCounterPosition ui4 AbsoluteTimePosition string CurrentMediaCategory string CurrentMediaDuration string CurrentPlayMode string NORMAL NORMAL REPEAT_ONE REPEAT_ALL CurrentRecordQualityMode string CurrentTrack ui4 0 0 65535 1 CurrentTrackDuration string CurrentTrackMetaData string CurrentTrackURI string CurrentTransportActions string LastChange string NextAVTransportURI string NextAVTransportURIMetaData string NumberOfTracks ui4 0 0 65535 PlayMode ui4 0 PlaybackStorageMedium string PossiblePlaybackStorageMedia string PossibleRecordQualityModes string PossibleRecordStorageMedia string RecordMediumWriteStatus string RecordStorageMedium string RelativeCounterPosition i4 RelativeTimePosition string TransportPlaySpeed string 1 1 12 -12 TransportState string STOPPED STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING TransportStatus string OK OK ERROR_OCCURRED X_Shuffle boolean 0Current device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-denon-com:device:AiosDevice:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27190900280 uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6 urn:schemas-upnp-org:device:MediaRenderer:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:bd84ddb6-c891-1b76-0080-0005cdb3dbd6 QPlay:1 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/scpd/renderer_dvc/AVTransport.xml /upnp/control/renderer_dvc/AVTransport /upnp/event/renderer_dvc/AVTransport urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/renderer_dvc/ConnectionManager.xml /upnp/control/renderer_dvc/ConnectionManager /upnp/event/renderer_dvc/ConnectionManager urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/scpd/renderer_dvc/RenderingControl.xml /upnp/control/renderer_dvc/RenderingControl /upnp/event/renderer_dvc/RenderingControl urn:schemas-denon-com:device:AiosServices:1 AiosServices Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 uuid:4b2ad4aa-1fc3-1eee-0080-0005cdb3dbd6 urn:schemas-denon-com:service:ErrorHandler:1 urn:denon-com:serviceId:ErrorHandler /upnp/scpd/AiosServicesDvc/ErrorHandler.xml /upnp/control/AiosServicesDvc/ErrorHandler /upnp/event/AiosServicesDvc/ErrorHandler urn:schemas-denon-com:service:ZoneControl:2 urn:denon-com:serviceId:ZoneControl /upnp/scpd/AiosServicesDvc/ZoneControl.xml /upnp/control/AiosServicesDvc/ZoneControl /upnp/event/AiosServicesDvc/ZoneControl urn:schemas-denon-com:service:GroupControl:1 urn:denon-com:serviceId:GroupControl /upnp/scpd/AiosServicesDvc/GroupControl.xml /upnp/control/AiosServicesDvc/GroupControl /upnp/event/AiosServicesDvc/GroupControl urn:schemas-denon-com:device:ACT-Denon:1 Marantz PM7000N Marantz http://www.marantz.com Marantz PM7000N Aios 4.025 BLL27190900280 uuid:77cfb03f-186d-408d-d12f-e5a82b56477f AIOS:0001 1 165840 Wed 2020-11-04 13:48:32 1.583.161 00:05:CD:B3:DB:D4 en_NA 4 Aios 4.025 1 Production 00:05:CD:B3:DB:D6 urn:schemas-denon-com:service:ACT:1 urn:denon-com:serviceId:ACT /ACT/SCPD.xml /ACT/control /ACT/event urn:schemas-upnp-org:device:MediaServer:1 Marantz PM7000N Marantz http://www.marantz.com Shares User defined folders and files to other Universal Plug and Play media devices. Marantz PM7000N Aios 4.025 BLL27190900280 uuid:cb238573-c03e-bbed-ddac-9f72c1c6a021 True True True True urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /upnp/scpd/ams_dvc/ContentDirectory.xml /upnp/control/ams_dvc/ContentDirectory /upnp/event/ams_dvc/ContentDirectory urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/scpd/ams_dvc/ConnectionManager.xml /upnp/control/ams_dvc/ConnectionManager /upnp/event/ams_dvc/ConnectionManagerUPnP devices found : 1
Device #0Marantz PM7000N UID: uuid:4d7b0675-1c74-1160-0080-0005cdb3dbd6 Location: http://192.168.0.2:60006/upnp/desc/aios_device/aios_device.xml
Max. memory for audio buffers: 7928MB
Local Audio Engine:WASAPI
Local devices found : 4
Device #0: JRiver Media Center (JRiver Media Center) Manufacturer: Model UID: JRiver Media Center (JRiver Media Center) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{50abaab2-9c1e-40f3-acf4-91ddebfe10a4}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #1: Alto-falantes (High Definition Audio Device) Manufacturer: Model UID: Alto-falantes (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{68b45fca-2335-4ac3-882f-ca924bc3a08a}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Áudio Digital (S/PDIF) (High Definition Audio Device) Manufacturer: Model UID: Áudio Digital (S/PDIF) (High Definition Audio Device) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{f1d47a72-1338-4566-8068-49b9b49178c3}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: LG IPS FULLHD (Áudio Intel® para telas) Manufacturer: Model UID: LG IPS FULLHD (Áudio Intel® para telas) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{dbdbf819-dc34-407c-a2c7-4bbbc8fe0511}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Can you disable upsampling in the audio output settings and try to play a track again?
I disabled SOX and it worked normal. It also worked in the Power of Two(x4) configuration of SOX, however the sampling rate was limited to 176,4Khz
With Power of 2 the frequency will be multiplied according to the track you play. What was the track frequency when you saw 176?
44,1khz, i understood. But why does 192khz (SoX with device max frequency upsampling) not work normally?
Do you have a 192khz track to be played without upsampling activated ?
No. I meant 192khz doing upsampling.
It’s possible that your DAC do not support upsampling with UPnP, you may need to deactivate it when you play to your PM7000N.
Ok. Thank you, very much.
I don’t know much about upsampling but some of the options work just fine on PM7000N via DLNA.
Here is an example of upsampling a 16/44 track to 24/192.
Humm. Cool! I will test with this configuration!
