Audirvana recognizes Dac but defaults to internal speaker output
Audirvana Mac Version 3.5.41 (3571)
macOS 10.15.7 with 8192MB RAM
Registered to dennis wygmans
	No plugin active
AUTO: /Volumes/OWC Envoy Pro EX/Music
iTunes/Music library synchronization: last synchronized on Sun Oct 25 17:06:03 2020
Library database path: /Users/denniswygmans/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
CA CXA81 2.0
Model UID:CA CXA81 2.0:22E8:CA02
UID:AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
ID 0x51 MacBook Pro Speakers Manufacturer:Apple Inc.
Model UID:Speaker UID:BuiltInSpeakerDevice
Stream ID 0x52 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x2f CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:1200000:1
Device #1: ID 0x51 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 1
Device #0: ID 0x0 Family Room UID: uuid:9ab0c000-f668-11de-9976-44fe3b6ced40 Location: http://192.168.1.20:49154/MediaRenderer/desc.xml
Sorry. Just noticed my DAC had turned off.
	No plugin active
CA CXA81 2.0
Active Sample Rate: 192kHz
ID 0x66 CA CXA81 2.0 Manufacturer:CA
Model UID:CA CXA81 2.0:22E8:CA02 UID:AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
9 available sample rates up to 705600Hz
Stream ID 0x67 2 channels starting at 1
27 virtual formats:
36 physical formats
Local devices found : 3
Device #0: ID 0x66 CA CXA81 2.0 Manufacturer: CA Model UID: CA CXA81 2.0:22E8:CA02 UID: AppleUSBAudioEngine:CA:CA CXA81 2.0:14300000:1
Device #1: ID 0x2f CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:1200000:1
Device #2: ID 0x51 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
Okay, can you try to play a song with iTunes when your DAC is connected? Does it output to your DAC?
Hiya,
I re-rebooted and it’s now working. Took a couple reboots I guess. All set.
Thank you,
Dennis
Do you mean the software volume control?
I had the same issue.
It doesn’t work for me.
I had the same issue and sent the bug report to Audirvana tech support. They suggested to go in audio output settings in Audirvāna and disable Software volume control? I disabled keyboard volume setting. Although the sound preference on the top right menu showed internal speaker was selected. But it played out in USB speakers. My Audirvana Origin Mac Version is 3.5.50 (3580) with macOS 10.15.7. Hope it helps.
Origin version can’t be 3.5.50… 3.5.x is Audirvana, not Studio, not Origin, so check what you have for real, then complain…
So after four years, this problem still hasn’t been resolved? I’m currently experiencing the same issue after working fine for months.
I am having this same issue - I’m using Audirvanna on my Mac Mini and everything is set correctly - however as soon as I play a track my audio out defaults back to the original Mac mini settings - can you please assist?
Hi @psidorenko,
I am also having the same issue. I have been using Audirvana 3.5 successfully but recently had the major problem described above.
My Audirvana 3.5 sees my DAC as the required output but as soon as I start to play the music it reverts to my Mac speakers resulting in no sound either from my HiFi speakers or my Mac speakers.
I need help, as from the above posts there does not seem to be an easy diagnostic procedure I can follow.
Thank you
EdSikora
