I’m using a Mac Mini M2 connected to the internet via a network cable.
Audirvana Remote only connects to my iPhone if I leave the Wi-Fi network on on the Mac Mini.
This started happening a few days ago. I’ve always used the Mac Mini with the Wi-Fi turned off. The firewall is turned off, and only Audirvana Origin is installed on the Mac Mini.
Has there been an update to the APP?
Hi @Reynaldo -
The wired and wi-fi are both the same network?
Hi @Jud
Yes, same network.
I have a modem/router from my internet provider.
On the back it has four RJ45 outputs and 5G Wi-Fi.
I always left the Mac Mini connected via cable and it worked normally with the iPhone using the 5G Wi-Fi network.
There has been a lot of discussion on the forum about the recent MacOS requirements regarding network permissions for apps. Could that be it?
(Sorry, but after this I’m out of ideas. )
Hi @Reynaldo,
Note: When you click on the Debug Info button, Audirvana automatically copies all its content. Please paste it in response to this message
Hi @Antoine
Here is the “Debug Info” with Wi-Fi turned off.
The Mac Mini is connected via cable.
Audirvana Origin 2.5.21 (20522)
macOS 15.4.1 ARM64 with 16GB physical RAM
Connected account of : Reynaldo
Local network access: allowed
r8brain custom frequencies
44100Hz → 352800Hz
48000Hz → 384000Hz
88200Hz → 352800Hz
96000Hz → 384000Hz
176400Hz → 352800Hz
192000Hz → 384000Hz
Sync list: 6 folders
AUTO: /Volumes/Musica/DSD64
AUTO: /Volumes/Musica/DSD128
AUTO: /Volumes/Musica/DSD256
AUTO: /Volumes/Musica/DSD512
AUTO: /Volumes/Musica/DXD
AUTO: /Volumes/Musica/FLAC
Sort and display order: en
Library database path: /Users/reynaldo/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on on port 49312
Font size: regular
Library
My Music
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 6118MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
iFi (by AMR) iFi (by AMR) HD USB Audio
UID:AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0050:1
Active Sample Rate: 768kHz
Selected device:iFi (by AMR) HD USB Audio
Manufacturer: iFi (by AMR)
Model name: iFi (by AMR) HD USB Audio
Model UID: iFi (by AMR) HD USB Audio:20B1:3008
UID: AppleUSBAudioEngine:iFi (by AMR):iFi (by AMR) HD USB Audio:0050:1
USB Vendor ID: 0x20b1
USB Product ID: 0x3008
ID 0x5f
Audio buffer frame size : 231 to 4096 frames
MQA Decoder device
DSD via PCM 1.0
Stream ID 0x60 2 channels starting at 1
40 virtual formats:
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
2 ch Non-mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
60 physical formats
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 768kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 705.6kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 384kHz
2 ch Mixable linear PCM Interleaved 24 little endian Signed Integer 352.8kHz
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 3
Device #0: ID 0x50 SONY TV *00
Manufacturer: SNY
Model UID: 4DD90480-0000-0000-011C-010380905178
Model name: SNY SONY TV *00
Device #1: ID 0x5f iFi (by AMR) HD USB Audio
Device #2: ID 0x4a Alto-falantes (Mac mini)
Model UID: Speaker
UID: BuiltInSpeakerDevice
Model name: Apple Inc. Alto-falantes (Mac mini)
Ethernet
UPnP devices found : 1
Device #0: ID 0x0 : XBR-65X905F
UID: uuid:23456789-1234-1010-8000-70260566F96B
Manufacturer: Sony Corporation
Model name: MediaRenderer
Chromecast devices found : 1
Device #0: XBR-65X905F
Model name: BRAVIA 4K GB ATV3
Problem solved.
I have another router here, I don’t know why the iPhone connected to the Wi-Fi network of this router, and this was causing the problem.
Now everything is working again.
Do you have an app on your computer that might block this port?
This computer is exclusively for audio, I only have Audirvana Origin installed.
