Here is the Debug data:
Audirvana Mac Version 3.5.29 (3559)
macOS 10.13.6 with 4096MB RAM
Registered to Ivo Bozhinov
iZotope SRC not in use iZotope SRC filter parameters
Steepness = 150
Filter max length = 500000
Cut-Off (x Nyquist) = 100%
Anti-aliasing = 200
Phase = 100%
Max allowed volume: 4.77387
Sync list: 2 folders
AUTO: /Volumes/Seagate 2T/Music
AUTO: /Users/ivobozhinov/Documents/Music
Library database path: /Users/ivobozhinov/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as
Preferred device: Primare NP5 Prisma Model UID:Primare Primare NP5 Prisma UID:uuid:e9fa6a76-9f3b-11ea-b94a-e9e9fcab342f
UPnP device at http://192.168.0.100:38400/description.xml
ID 0x0 Primare NP5 Prisma Manufacturer:Primare
Volume control: No
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO
http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/3gpp:DLNA.ORG_PN=AAC_ISO_320
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS
http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAPRO
http-get::audio/aiff:
http-get::audio/x-aiff:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
12 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 1:36:11.000
CurrentURI:
CurrentURIMetadata:
nextURI: http://192.168.0.110:49152/audirvana/audio_1_24.wav
nextURIMetadata:
dc:titleSlow Blues Mix (MM REMASTER)</dc:title>
dc:creatorIvo aka PRIMARE</dc:creator>
upnp:artistIvo aka PRIMARE</upnp:artist>
upnp:genreBlues</upnp:genre>
upnp:albumArtURIhttp://192.168.0.110:49152/audirvana/artwork_1_25.jpg</upnp:albumArtURI>
upnp:albumSlow Blues Mix</upnp:album>
PlayMedium: NONE
<?xml version="1.0"?>1
0
SetAVTransportURI
InstanceID
in
A_ARG_TYPE_InstanceID
CurrentURI
in
AVTransportURI
CurrentURIMetaData
in
AVTransportURIMetaData
SetNextAVTransportURI
InstanceID
in
NextURI
in
NextAVTransportURI
NextURIMetaData
in
NextAVTransportURIMetaData
GetMediaInfo
InstanceID
in
NrTracks
out
NumberOfTracks
MediaDuration
out
CurrentMediaDuration
CurrentURI
out
AVTransportURI
CurrentURIMetaData
out
NextURI
out
NextAVTransportURI
NextURIMetaData
out
PlayMedium
out
PlaybackStorageMedium
RecordMedium
out
RecordStorageMedium
WriteStatus
out
RecordMediumWriteStatus
GetTransportInfo
InstanceID
in
CurrentTransportState
out
TransportState
out
TransportStatus
CurrentSpeed
out
TransportPlaySpeed
GetPositionInfo
InstanceID
in
Track
out
CurrentTrack
TrackDuration
out
CurrentTrackDuration
TrackMetaData
out
CurrentTrackMetaData
TrackURI
out
CurrentTrackURI
RelTime
out
RelativeTimePosition
AbsTime
out
AbsoluteTimePosition
RelCount
out
RelativeCounterPosition
AbsCount
out
AbsoluteCounterPosition
GetDeviceCapabilities
InstanceID
in
PlayMedia
out
PossiblePlaybackStorageMedia
RecMedia
out
PossibleRecordStorageMedia
RecQualityModes
out
PossibleRecordQualityModes
GetTransportSettings
InstanceID
in
PlayMode
out
CurrentPlayMode
RecQualityMode
out
CurrentRecordQualityMode
SetPlayMode
InstanceID
in
NewPlayMode
in
CurrentPlayMode
Stop
InstanceID
in
Play
InstanceID
in
Speed
in
TransportPlaySpeed
Pause
InstanceID
in
Seek
InstanceID
in
Unit
in
A_ARG_TYPE_SeekMode
Target
in
A_ARG_TYPE_SeekTarget
Next
InstanceID
in
Previous
InstanceID
in
GetCurrentTransportActions
InstanceID
in
Actions
out
TransportState
string
STOPPED
PAUSED_PLAYBACK
PLAYING
TRANSITIONING
NO_MEDIA_PRESENT
TransportStatus
string
OK
ERROR_OCCURRED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
NONE
RecordStorageMedium
string
NOT_IMPLEMENTED
string
UNKNOWN
CD-DA
DVD-VIDEO
HDD
string
NOT_IMPLEMENTED
CurrentPlayMode
string
NORMAL
SHUFFLE
REPEAT_ONE
REPEAT_TRACK
REPEAT_ALL
NORMAL
TransportPlaySpeed
string
1
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
string
NOT_IMPLEMENTED
NumberOfTracks
ui4
0
1
CurrentTrack
ui4
0
1
1
string
string
string
CurrentTrackURI
string
AVTransportURI
string
string
NextAVTransportURI
string
string
string
string
i4
i4
string
LastChange
string
A_ARG_TYPE_SeekMode
string
ABS_COUNT
TRACK_NR
REL_TIME
string
ui4
0
<dlna:X_DLNADOC xmlns:dlna=“urn:schemas-dlna-org:device-1-0”>DMR-1.50</dlna:X_DLNADOC>
Primare NP5 Prisma
Primare
PrimareDMR
Primare NP5
1.0
http://www.primare.net/products/np5-prisma/
1234567890
/RenderingControl.xml
/RenderingControl
/RenderingControl/eventSub
/AVTransport.xml
/AVTransport
/AVTransport/eventSub
/ConnectionManager.xml
/ConnectionManager
/ConnectionManager/eventSub
UPnP devices found : 2
Device #0: ID 0x0 Primare NP5 Prisma UID: uuid:e9fa6a76-9f3b-11ea-b94a-e9e9fcab342f Location: http://192.168.0.100:38400/description.xml
Device #1: ID 0x0 Qute-9B31 UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A89B31 Location: http://192.168.0.101:8080/description.xml
Max. memory for audio buffers: 1792MB
Device #0: ID 0x2b Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:108 UID: AppleHDAEngineOutput:1B,0,1,2:0
Device #1: ID 0x3a Naim DAC-V1. Audiophilleo.com Manufacturer: Naim Audiophilleo Model UID: Naim DAC-V1. Audiophilleo.com:279A:0001 UID: AppleUSBAudioEngine:Naim Audiophilleo:Naim DAC-V1. Audiophilleo.com: 00000:2
