Audirvana stop playing song question had done!
sorry my english is poor,I hope you sucess!
upnp–》dac
set different ip to dac。
such like dac ip is 192.168.1.111 ,change it to 192.168.2.111 or 192.168.3.111
the question done!
If I understand well … UPNP works only on the same subnet.
That said if Audirvana is on 192.168.1 subnet the UPNP dac must be on the very same subnet: if you want to change the UPNP dac address must be 192.168.1.10 or 192.168.1.20 (just as an example).
If you change from 192.168.1.111 to 192.168.2.111 you’re changing the subnet and UPNP will not work
sorry ,now It doesn’t working.
