Hi,
when I connect my AK SR15 via UPnP the track stops at the end and does not move to the next track, I have no issue when the AK SR15 is connected directly as external DAC via USB.
Below is the log, thanks for the support
Luigi
Audirvana Mac Version 3.5.33 (3563)
macOS 10.13.6 with 16384MB RAM
Bandwidth at 0dB = 94.9611
Phase = 51
Sync list: 2 folders
AUTO: /Volumes/Multimedia/Music
AUTO: /Users/luigi/Music
Library database path: /Users/luigi/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: SR15 Luigi Model UID:IRIVER Ltd. SR15 Luigi UID:uuid:4d696e69-8398-a115-0102-0018d56bf1e6
UPnP device at http://192.168.2.3:5500/upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/desc
ID 0x0 SR15 Luigi Manufacturer:IRIVER Ltd.
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/mp4:DLNA.ORG_PN=M4A;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-wav:DLNA.ORG_PN=WAV;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMA;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/ogg:DLNA.ORG_PN=OGG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/aac:DLNA.ORG_PN=AAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/x-ape:DLNA.ORG_PN=APE;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/dsf:DLNA.ORG_PN=DSF;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/dff:DLNA.ORG_PN=DSD;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get::audio/aiff:DLNA.ORG_PN=AIFF;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
http-get:*:audio/flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=40000000000000000000000000000000
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
13 virtual formats:
0 physical formats
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 SR15 Luigi IRIVER Ltd. http://www.iriver.com DMR on Astell&Kern AK Connect Renderer 1.0 http://www.iriver.com 0000-0000-0000-0000 uuid:4d696e69-8398-a115-0102-0018d56bf1e6 000000000000 image/png 48 48 8 /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/icon_48 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/ConnectionManager/desc /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/ConnectionManager/action /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/ConnectionManager/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/AVTransport/desc /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/AVTransport/action /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/AVTransport/event urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/RenderingControl/desc /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/RenderingControl/action /upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/svc/upnp-org/RenderingControl/eventUPnP devices found : 1
Device #0: ID 0x0 SR15 Luigi UID: uuid:4d696e69-8398-a115-0102-0018d56bf1e6 Location: http://192.168.2.3:5500/upnp/dev/4d696e69-8398-a115-0102-0018d56bf1e6/desc
Max. memory for audio buffers: 14106MB
Integer mode: Disabled
Device #0: ID 0x2e Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
