New install. After my usual struggle to get driver working in new ibstallation today’s attempt finally works but super briefly. It started allowing playback for mere seconds before quitting. For some reason a few minutes might be allowed now but srillbstops before first song has end. Track forward button works but still doesn’t allow a full track to be played.
Hello @michael.anda,
Audirvana 3.5.40
Sync list: 0 folders
Library database path: C:\Users\micha\AppData\Local\Audirvana\AudirvanaPlus\AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 732MB
Local Audio Engine:WASAPI
Speakers (DENAFRIPS USB DAC)
Model UID:Speakers (DENAFRIPS USB DAC)
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{1c50fe42-40f6-4739-9ed2-18b45c37bf01}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Speakers (DENAFRIPS USB DAC) Manufacturer:
Model UID:Speakers (DENAFRIPS USB DAC) UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{1c50fe42-40f6-4739-9ed2-18b45c37bf01}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
12 available sample rates up to 1536000Hz
1411200
1536000
Simple stereo device: No
2 ch Integer PCM 16bit little endian 1411.2kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1411.2kHz
2 ch Integer PCM 32bit little endian 1411.2kHz
2 ch Integer PCM 16bit little endian 1536kHz
2 ch Integer PCM 24bit little endian aligned high in 32bit chunk 1536kHz
2 ch Integer PCM 32bit little endian 1536kHz
Device #0: Speakers (DENAFRIPS USB DAC) Manufacturer: Model UID: Speakers (DENAFRIPS USB DAC) UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{1c50fe42-40f6-4739-9ed2-18b45c37bf01}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
I took out my USB Disrupter and the problem ceased and desisted.
I had barely hit the ENTER key on my last response when the issue started up again.
Try to switch to ASIO. Disable MQA auto detection.
Thanks. I’ll look at that tomorrow.
ASIO and Master off doesn’t solve matters.
Try to make the preload buffer larger, something like 2048 or 4096 MB, depending on how much RAM you have.
