MacJK
March 31, 2022, 1:58pm
1
Hello, since Update to 1.12.2 the Radio playback crash after some time.
I cant measure but it seam to be 15min or more. After AS crash i need restart the application.
On older version i don’t have this problem. I think this is releadt to the buffer improvement.
Any help? (Windows 11)
Best Regards
MacJK
Hello @MacJK ,
Can you send us your audirvana.log and audirvana.dmp file at [email protected] ?
to show AppData folder:
MacJK
March 31, 2022, 5:39pm
3
Hello @Antoine , thx and on the way.
Best Regards
MacJK
MacJK
April 21, 2022, 3:01pm
4
Hello, some update on this topic?
Some more Info:
I test some file play and this work more then 24h without crash. Memory uses skips based on content what make sense in my opinion.
But after stop or new file the memory seam to be released.
Anytime I start radio play back the memory goes up and after 7 min the playback stop.
Without Release of Memory.
Best Regards
MacJK
I couldn’t find time to do more try on my side but will surely do if can tomorrow.
MacJK
May 22, 2022, 4:22pm
6
from : The radio stops - Audirvāna Studio / Radio & Podcasts - Audirvana
Hello, long time no Update.
Today got notified of a new Version.
1.13.0.
So far it looks like it be fixed my Play-back runs since 4h and the memory consumption looks ok.
I do some more long-play over next week.
Thanks.
system
Closed
August 20, 2022, 4:22pm
7
