Audirvana Studio 2.8.1.3 on Linux - Unable to Unlock Audio Device
If you also issue
sudo systemctl disable audirvanaStudio
does the problem still occur?
I think there is a confusion going on here about what is meant with ā€˜lock’. What do you mean when you say that Audirvana locks your disk?
Yes stopping aidivarnaStudio service and rebooting.
I get the following jpg message.
BTW did you receive the log I tried to send you 2 days ago because i didn’t get any ackowledgement from your mail sysytem.
The hd contanimg the music is off line….
rebootin iPad
Will reboot linux box again.
Stay tuned….
shutting down the Linux box i get the follwing message
music hd is online and readable, Compilations and CLASSICAL directories are readable.
reboot iPad
I still cannot add Compilations, I still get Request error.
Did you receive the log I uploaded two days ago?
I am sending you the log for today.
Please confirm that you have received it.
BTW is it possible to have/use a spellchecker in your message system?
Thanks for your help.
As a last straw I wll try to erase and update the database one more time.
Did you send the file using the email you have on the forum?
Please don’t take offense. Just trying to help here.
I have quite satisfying results using ChatGPT with issues. I upload the pictures and ChatGPT gives directions to solve the problem.
Certainly not the holy grail, but it may prevent you from waiting for replies here in the forum.
If you don’t want to use AI that’s fine ofcourse, but for me with these kind of questions it has proven itself helpful.
