I have deleted the Library path from the Settings local so that i can add new path and new library but the old albums continue to show and can even play
in case i add back the old path then there are duplicate tracks showing
I dont know why
Roon has a simple method disable or delete the storage path and whooom its gone
Can Audirvana studio not do the same
old Audirvn 3.5 was good no problem at all
