Audirvana Studio not launching after first time
The first time I tried to open Audirvana Studio, it worked fine. After a reboot, it no longer works and I get an UnhandledException error. Checking the log, it says “System.Security.Cryptography.CryptographicException: The data is invalid.” It’s the first item in the log after it says “Started logging”. A reinstall didn’t help.
For reference I’m on Windows 11
Hello @cinderithink,
This error can be related to a missing windows update or the .NET framework not being up to date or broken.
Can you reinstall it here (you should take the recommended one)?
