Audirvana Studio on Synology NAS
I’m operating a Synology NAS with the following specs:
Synology DS920+
CPU: Intel Celeron 14125 @2 GHz
4 GB RAM
DSM 7.2.1-69057 Update 5
witch spk version should I use to install Audirvana Studio?
thx and brgds
Herbert
I think you can find your answers here.
Thanks for your hint,
I allready had a look there and found only two download versions for different processor architecture: ARM64 and AMD.
What’s happen if the NAS is based on Intel architecture like mine?
Damien from Audirvãna has stated something about that here
AMD version is the right for you, even if you use an Intel chip. When it comes to the version of software, you won’t see a lot of Intel 64-named software: x86-64 - Wikipedia
Good morning Antoine, thanks a lot for your advise. I’ll go on with it :slight_smile:
Herbert
