Audirvana Studio to ultraRendu (MPD/DLNA) problems
Hi all
I’m having trouble getting Audirvana Studio to work with my Sonore ultraRendu.
Back in the day, I used Audirvana 3 with the ultraRendu successfully. Then I switched to Roon for a couple years, which worked with the ultraRendu via its Roon Ready settings. I’ve recently decided to return to Audirvana Studio as I prefer its sound quality and its metadata system.
Audirvana Studio recognizes the ultraRendu when it’s in MPD/DLNA mode. However songs stop playing after a few seconds, or don’t play at all, or very rarely I get lucky with a few minutes of music. I’ve found advice in other threads to use the uR’s MPD/DLNA compatibility mode (which I’ve done), and AS’s “do not use raw PCM” switch (which I’ve done), but the problems persist.
Interestingly, AS also won’t recognize the uR in Shairport mode, which normally is a fairly reliable back-up approach.
AS is effectively unusable for me now, so I’ve gone back to Roon. But really hoping I can find a solution as I much prefer the SQ and metadata system of AS. Any thoughts on what I could try?
RC
Hello @defiantscientist,
Thanks @Antoine.
Here it is:
Audirvana Studio 1.10.2 (11002)
macOS Version 12.1 (Build 21C52) with 16GB physical RAM
Connected account of :
AUTO: /Volumes/music/ravimusic
Library database path: /Users/ravichhatpar/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56508
Preferred device: JF LIGHT INDUSTRIES URENDU-013BA9-UPNP/AV Model UID:JF Light Industries urendu-013BA9-UPnP/AV UID:uuid:ebca356d-a94e-780c-9f31-d063b4013ba9
UPnP device at http://192.168.1.16:49153/uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/description.xml
ID 0x0 urendu-013BA9-UPnP/AV
Manufacturer: JF Light Industries
Model Name:
Model UID: JF Light Industries urendu-013BA9-UPnP/AV
UID: uuid:ebca356d-a94e-780c-9f31-d063b4013ba9
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: Yes
http-get::application/flac:
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp3:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
8 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 00:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 urendu-013BA9-UPnP/AV JF Light Industries https://framagit.org/medoc92 UPnP front-end to MPD UpMPD 42 https://framagit.org/medoc92/upmpdcli/code/ upmpdcli version 1.5.12 libupnpp 0.21.0 image/png 64 64 32 /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/icon.png /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/presentation.html uuid:ebca356d-a94e-780c-9f31-d063b4013ba9 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/evt-urn-schemas-upnp-org-service-ConnectionManager-1
UPnP devices found : 1
Device #0: ID 0x0 urendu-013BA9-UPnP/AV UID: uuid:ebca356d-a94e-780c-9f31-d063b4013ba9 Location: http://192.168.1.16:49153/uuid-ebca356d-a94e-780c-9f31-d063b4013ba9/description.xml
Device #0: ID 0x53 MacBook Pro Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. MacBook Pro Speakers
Device #1: ID 0x2e ZoomAudioDevice Manufacturer: zoom.us Model UID: zoom.us.zoomaudiodevice UID: zoom.us.zoomaudiodevice.001 Model Name: zoom.us ZoomAudioDevice
@Antoine this is exactly the problem I am currently having with the MicroRendu.
@defiantscientist so far, this has been unresolvable. I have posted extensively about it in another thread here.
Hopefully, @Antoine can get us some answers. So far, apparently, he has been unable to reproduce the issue.
@defiantscientist, have you had any luck getting your Rendu to work with AS?
Maybe this is relevant? I have an original signature series rendu, SPDIF output, which is basically a beefed up microrendu with an internal linear power supply. It’s connected to my network via a LAN cable/network switch. Since day one I have had nearly zero issues streaming local and external, Quobuz, content. A couple of times a month the music will repeatedly “skip” at the same spot, like a scratch on a record that prevents the needle from moving forward. The fix is always to reboot the Sonore. Anyway, let me know if posting my debugg info might help?
@defiantscientist and @GaseousClay ,
Can you both click on DAC diagnostics while you have your issue?
Thanks @Antoine for investigating further.
I just upgraded AS to the latest version 1.11.0, then started playing music successfully for a few minutes (which is further than I got before when I posted the message above), and then the same issue returned.
Here’s what I see on DAC Diagnostics:
Signalpath International Peachtree USB DAC at usb-ci_hdrc.1-1.1, full speed : USB Audio
Playback:
Status: Running
Interface = 3
Altset = 2
Packet Size = 432
Momentary freq = 48000 Hz (0x30.0000)
Interface 3
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 3 OUT (ADAPTIVE)
Rates: 8000, 16000, 32000, 44100, 48000, 96000
Bits: 16
Interface 3
Altset 2
Format: S24_3LE
Channels: 2
Bits: 24
access: RW_INTERLEAVED
format: S24_3LE
subformat: STD
channels: 2
rate: 48000 (48000/1)
period_size: 6000
buffer_size: 24000
Simple mixer control ‘PCM’,0
Capabilities: pvolume pswitch pswitch-joined
Playback channels: Front Left - Front Right
Limits: Playback 0 - 110
Mono:
Front Left: Playback 110 [100%] [0.00dB] [on]
Front Right: Playback 110 [100%] [0.00dB] [on]
Signalpath International Peachtree USB DAC at usb-ci_hdrc.1-1.1, full speed : USB Audio #1
Playback:
Status: Stop
Interface 3
Altset 3
Format: S16_LE
Channels: 2
Rates: 48000
Bits: 0
Status: Unknown (status not available when device is not playing)
Mono:
Will do. I should be back in front of my computer tomorrow.
Hello @defiantscientist ,
Can you activate upsampling and use the setting custom to upsample any frequency to 24/96 and try to play a track again?
Here you go, @Antoine. Please let me know if you are able to do anything, before my trial is over. I’d still like to be able to use the software to play music for at least a couple of days.
Thanks.
Schiit Audio Schiit Yggdrasil Unison USB at usb-ci_hdrc.1-1.1, high speed : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 1 OUT (ASYNC)
Rates: 44100, 48000, 88200, 96000, 176400, 192000
Data packet interval: 125 us
Bits: 16
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates:
Bits: 24
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Rates:
Bits: 32
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
It’s all you have for your device? Nothing more? I will send it to Sonore so make sure you have everything in it.
Would you like a screen recording?
Here’s another one, with it playing, using Audirvana Plus 3.2.20, since AS doesn’t play.
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 144
Momentary freq = 192002 Hz (0x18.0014)
Feedback Format = 16.16
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Bits: 16
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates:
Bits: 24
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Rates:
Bits: 32
format: S16_LE
subformat: STD
channels: 2
rate: 192000 (192000/1)
period_size: 24000
buffer_size: 96000
Mono: Playback [on]
@Antoine, I just tried installing the update. I tried playing a cd-quality track, and I got the old, familiar “Initializing…, Loading…” stop. Nothing.
Here are the DAC diagnostics, after that rather predictable fiasco:
Playback:
Status: Stop
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Bits: 16
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates:
Bits: 24
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Rates:
Bits: 32
Mono: Playback [on]
@Antoine, here is the diagnostic report, with a “burst of noise” MQA track playing:
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 68
Momentary freq = 88202 Hz (0xb.0676)
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Bits: 16
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates:
Bits: 24
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Rates:
Bits: 32
format: S16_LE
subformat: STD
channels: 2
rate: 88200 (88200/1)
period_size: 11025
buffer_size: 44100
Mono: Playback [on]
Finally, @Antoine, here is the report with the player stuck one second into a cd-quality track. I skipped to this track, after clearing the DLNA and MPD caches, in the SonicOrbiter software, playing the MQA track that composed the above report, and the player froze, one second into the track. If I try to play the next track, I once again get “Initializing, Loading, stop”.
Playback:
Status: Running
Interface = 1
Altset = 1
Packet Size = 36
Momentary freq = 44101 Hz (0x5.833f)
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Bits: 16
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Rates:
Bits: 24
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Rates:
Bits: 32
format: S16_LE
subformat: STD
channels: 2
rate: 44100 (44100/1)
period_size: 5513
buffer_size: 22050
Mono: Playback [on]
So there you have it, @Antoine. I hope that helps. The software remains unusable for me.
I await your response.
Thanks.
Hi @Antoine
I activated upsampling and used the custom setting to upsample all frequencies to 96 kHz (see attached screenshot).
I was able to play music for about 5 minutes, jumping across a few tracks. Then the same issue came up again and can not play any tracks. Restarted AS and still can’t play any tracks.
However, turned off my full sound system (including the ultraRendu) and then turned it back on again, then restarted AS. I can then play tracks for a few mins again before the issue returns and can’t play any tracks.
Ravi
