I own the GoodHerz CanOpener VST plugin which I’ve been using with Audirvana for a relatively long time.
In Audirvana Studio I can include it as part of the signal processing chain, but it does not seem to be used. If I play back any file in my library and access the play back options while it plays, under “Processing” it won’t show anything. (I’m using Kernel Streaming on Windows 10)
If I stop the play back, CanOpener reappears under “Processing”.
