Yes of course, please find it enclosed:
Audirvana Mac Version 3.5.34 (3564)
macOS 10.15.4 with 8192MB RAM
Registered to **********
SW volume control: ON
AUTO: /Volumes/Audio/Linear
Library database path: /Users/********/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 1008MB
OWC Thunderbolt 3 Audio Device
Model UID:OWC Thunderbolt 3 Audio Device:1E91:4001
UID:AppleUSBAudioEngine:Other World Computing:OWC Thunderbolt 3 Audio Device:1400000:1
Active Sample Rate: 48kHz
Sample rate limitation: 96kHz
Limit bitdepth to 24bit: ON
ID 0x32 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:125 UID:AppleHDAEngineOutput:1B,0,1,1:0
Stream ID 0x33 2 channels starting at 1
4 virtual formats:
4 physical formats
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:125 UID: AppleHDAEngineOutput:1B,0,1,1:0
