Audirvana vs Rose150b
Hi,
I can’t believe it
I just started the Audirvana test and…it finds several devices (speakers connected to the PC and the TV that connects via wifi) but it doesn’t find the ROSE150b streamer that are connected to the same network.
Please help
Welcome…
Please paste your Debug information here, so folks can help you the best possible… it is found here: Settings–> My Account–> Help–> Debug information.
It will also help to describe your network configuration. :wink:
Hi
Thnks for your support.
I have connected the Rose150b by wifi.
Here is the debug information:
Audirvana Studio 2.8.2 (20802)
Windows 10 (19045) with 16GB physical RAM
Connected account of : ignacio moure
Available network interfaces:
Ethernet ({6b88fe52-b353-48f9-beb2-58343d5ff9af}) is PUBLIC
Active profile types: all
Private profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Notifications: enabled
Public profile:
Firewall: enabled
Inbound: blocked
Outbound: allowed
Network interface INBOUND traffic is BLOCKED: potential issue for Remote, UPnP, and Chromecast
AUTO: C:\Users\nacho\Music
Library database path: C:\Users\nacho\AppData\Local\Packages\Audirvana.Audirvana-4118-9684-d80dbb7827cd_q3nymrkmej12j\LocalCache\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Fingerprinting track 4889/16674 : C:\Users\nacho\Music\DSD-Music\Al Di Meola _ John McLaughlin _ Paco De Lucia - Friday Night In San Francisco (IMPEX LP DSD 256)\01 - Mediterranean Sundance - Rio Ancho.dsf
Listening on 192.168.1.129 on port 49573
UI theme: light
Font size: large
Language: Idioma del sistema
Mi música
Señales de radio
Podcasts
Streaming
Locales
Startup view: Mi Música: Álbumes
Use media keys: no
Use media keys for volume control: no
Number of paired remotes: 1
Screen saver disabled: yes
Max. memory for audio buffers: 8192MB
Local Audio Engine: WASAPI
Interfaz SPDIF (2- HiResDAC FX-04J)
Model UID:USB\VID_040D&PID_340F&REV_0101&MI_00
UID:\?\SWD#MMDEVAPI#{0.0.0.00000000}.{33776dc5-7e76-4627-adc2-9a12a9c4d2c1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device: 2ch 16bits Integer, 4 bytes per frame 48kHz
Active Sample Rate: 48kHz
Selected device:Interfaz SPDIF (2- HiResDAC FX-04J)
Manufacturer: (Audio USB genérico)
Model name: HiResDAC FX-04J
Model UID: USB\VID_040D&PID_340F&REV_0101&MI_00
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{33776dc5-7e76-4627-adc2-9a12a9c4d2c1}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
USB Vendor ID: 0x040d
USB Product ID: 0x340f
Simple stereo device: No
Local devices found : 4
Device #0: Interfaz SPDIF (2- HiResDAC FX-04J)
Device #1: Realtek Digital Output (Realtek(R) Audio)
Manufacturer: Realtek
Model UID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_1462EC04&REV_1003
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{d72d4b6a-a53d-4ab4-ac0a-c1373327d04d}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #2: Altavoces (2- HiResDAC FX-04J)
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{5f027476-08e0-4f1b-ab66-6c955956bc06}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Device #3: BenQ GW2790QT (Sonido Intel(R) para pantallas)
Manufacturer: Intel(R) Corporation
Model UID: HDAUDIO\FUNC_01&VEN_8086&DEV_280B&SUBSYS_80860101&REV_1000
UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{cd4f6671-1a5e-42d8-acc8-b90bc64861a7}#{e6327cad-dcec-4949-ae8a-991e976a79d2}
Chromecast devices found : 1
Device #0: TV del salón
Model name: Smart TV Pro
Maybe @Antoine can have a look. There have been several issues over the last year, so there might be a quick solution for this.
It may be related to the firewall… Note the debug report line highlighted in bold text below and the link to a thread regarding firewall settings…
Thanks for the info.
I went to the firewall and I directly disabled it completely to check for interference.
Everything remains the same: Audirvana does not detect the Rose150, which of course is on.
What else could it be?
Is the MAC ID being allowed on your router?
I don’t know what the MAC is exactly, but I went to look at the router and something like this appears= MAC Adress: f4:3c:3b: …
and some more characters
is this it?
Additionally, I have tried to connect the Android app from my mobile… and nothing. The wifi is the one I have at home, there is no other. I even set the PC to connect to the router via wifi, and not with a direct cable which is the usual, so that both PC and mobile were connected via wifi to the same network, and nothing… it gives errors and does not connect to Audirvana.
I don’t understand.
Help
Now…Now, I turn on the audirvana…and ¡surprise¡¡ now the Firewall dialog box appears, allowing it to play, obviously authorizing it and…the app on the mobile is working, but it continues without detecting the Rose150b which is my main playback source. . Well, something has progressed, but…it’s not enough. Now i know that the firewall is controlled.
Should I do something in the Rose?
Is the laptop connected with the 5Ghz wifi, as is the Rose? I had some issues like this, and I had success by making sure all devices were connected to the same endpoint and the same band. And in my case it helps by restarting the moden and router from time to time. I have a Naim ND5 XS2 by the way.
Thank you…I’ve already restarted everything, I’ve already checked the 5g wifi network, everything connected to the network…and it detects the TV but it doesn’t detect the Rose 150b, and the TV is on top of the Rose…I don’t understand what’s happening
I just need to restart myself hahah
thanks for your help
You need to get a baseline reference that is working…
This can be done by making a simple Ethernet connection from the computer to the Streamer… If this works, you have a starting-point from which to sort-out your network… If it does not work, it’s time to contact the HIFI Rose folks about the behavior.
It’s too much for me. i’m a normal user.
It can’t be so complicated…and if is it, i will say goodbye audinirvana
Sorry
This does not seem to be an issue with Audirvana specifically… From the “Plays with Audirvana.” category on the community page:
It seems related to your network configuration:
Is the Rose connected with an ethernet cable to your network? Or just WiFi?
I try it with the two ways,with cable and with wifi
Don’t work with both
Computer → Streamer
Hi @IMIM,
Can you go into the Audirvāna settings and in the My Account section? You will see a ‘Start Log Session’ button; click on it and reproduce your issue. After you reproduce it, click 'Stop Log Session’ and send the audirvana_studio.log file you can find by clicking 'Open Log Folder’ at support@audirvana.com
