both the speakers and USB devices are too loud.
macOS 13.0.1 with 32768MB RAM
AUTO: /Users/Name/Music/Qobuz
Library database path: /Users/Name/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 16020MB
Exclusive access: Disabled
D90SE
Model UID:D90SE:152A:8750
UID:AppleUSBAudioEngine:Topping:D90SE:8330000:1
Active Sample Rate: 48kHz
Sample rate limitation: 96kHz
ID 0x70 D90SE Manufacturer:Topping
Model UID:D90SE:152A:8750 UID:AppleUSBAudioEngine:Topping:D90SE:8330000:1
Stream ID 0x71 2 channels starting at 1
30 virtual formats:
40 physical formats
Local devices found : 5
Device #0: ID 0x61 LG TV SSCR2 Manufacturer: GSM Model UID: 1E6DC8C0-0000-0000-011E-010380A05A78 UID: 1E6DC8C0-0000-0000-011E-010380A05A78
Device #1: ID 0x70 D90SE Manufacturer: Topping Model UID: D90SE:152A:8750 UID: AppleUSBAudioEngine:Topping:D90SE:8330000:1
Device #2: ID 0x37 Mic
Device #3: ID 0x5a Mac-speakers UID: BuiltInSpeakerDevice
Device #4: ID 0x33
