macOS 10.15.2 with 4096MB RAM
Registered to Michael Clarke
Per track: OFF
Sync list: 0 folders
iTunes/Music library synchronization: last synchronized on Sat Apr 3 15:07:51 2021
Library database path: /Users/michaelclarke/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
TIDAL: Connected as FREE
Preferred device: mrendu-01EE43 Model UID:JF Light Industries mrendu-01EE43 UID:uuid:b74470f1-a552-9ec8-38a8-d063b401ee43
Currently playing to UPnP device at 32 bits 384kHz
UPnP device at http://10.0.0.61:49152/uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/description.xml
ID 0x0 mrendu-01EE43 Manufacturer:JF Light Industries
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::application/flac:*
http-get::application/x-flac:
http-get::application/ogg:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/aac:
http-get::audio/x-aiff:
http-get::audio/aif:
http-get::audio/aiff:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/matroska:
http-get::audio/x-matroska:
http-get::audio/mp1:
http-get::audio/mp4:
http-get::audio/mpeg:
http-get::audio/x-mpeg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-ape:
http-get::audio/ape:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/wave:
http-get::audio/x-ms-wma:
http-get::audio/x-ogg:
http-get::audio/x-scpls:
http-get::audio/x-vorbis+ogg:
http-get::audio/x-vorbis:
http-get::audio/x-wavpack:
http-get::video/mp4:
DLNA 1.5: No
Gapless playback: Yes
Can play native DSD: Yes
28 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:04:47
CurrentURI: http://10.0.0.124:49152/audirvana/audio_0_3.wav
CurrentURIMetadata: <?xml version="1.0" encoding="utf-8"?>dc:titlePut Your Lights On</dc:title>mpdupnp:classobject.item.audioItem.musicTrack</upnp:class>upnp:albumSupernatural</upnp:album>upnp:originalTrackNumber3</upnp:originalTrackNumber>http://10.0.0.124:49152/audirvana/audio_0_3.wavdc:creatorSantana Feat. Everlast</dc:creator>upnp:artistSantana Feat. Everlast</upnp:artist>
nextURI: http://10.0.0.124:49152/audirvana/audio_1_5.wav
nextURIMetadata:
dc:titleAfrica Bamba</dc:title>
dc:creatorSantana</dc:creator>
upnp:artistSantana</upnp:artist>
upnp:genre</upnp:genre>
upnp:originalTrackNumber4</upnp:originalTrackNumber>
PlayMedium: HDD
<?xml version="1.0"?> 1 0 TransportState no string STOPPED PLAYING TransportStatus no string OK ERROR_OCCURRED PlaybackStorageMedium no string PossiblePlaybackStorageMedia no string RecordStorageMedium no string PossibleRecordStorageMedia no string CurrentPlayMode no string NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL RANDOM DIRECT_1 NORMAL TransportPlaySpeed no string 1 no RecordMediumWriteStatus string CurrentRecordQualityMode no string PossibleRecordQualityModes no string NumberOfTracks no ui4 0 2000 1 CurrentTrack no ui4 0 2000 1 CurrentTrackDuration no string CurrentMediaDuration no string CurrentTrackMetaData no string CurrentTrackURI no string AVTransportURI no string AVTransportURIMetaData no string NextAVTransportURI no string NextAVTransportURIMetaData no string RelativeTimePosition no string AbsoluteTimePosition no string RelativeCounterPosition no i4 AbsoluteCounterPosition no i4 CurrentTransportActions no string LastChange yes string A_ARG_TYPE_SeekMode no string ABS_TIME REL_TIME A_ARG_TYPE_SeekTarget no string A_ARG_TYPE_InstanceID no ui4 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 1 urn:schemas-upnp-org:device:MediaRenderer:1 mrendu-01EE43 JF Light Industries https://opensourceprojects.eu/u/medoc/profile/ UPnP front-end to MPD UpMPD 42 https://opensourceprojects.eu/p/upmpdcli/code/ upmpdcli version 1.4.7 libupnpp 0.17.2 image/png 64 64 32 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/icon.png /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/presentation.html uuid:b74470f1-a552-9ec8-38a8-d063b401ee43 urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-schemas-upnp-org-service-AVTransport-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-schemas-upnp-org-service-AVTransport-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-schemas-upnp-org-service-AVTransport-1 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-schemas-upnp-org-service-RenderingControl-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-schemas-upnp-org-service-RenderingControl-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-schemas-upnp-org-service-RenderingControl-1 urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-schemas-upnp-org-service-ConnectionManager-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-schemas-upnp-org-service-ConnectionManager-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-schemas-upnp-org-service-ConnectionManager-1 urn:av-openhome-org:service:Info:1 urn:av-openhome-org:serviceId:Info /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Info-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Info-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Info-1 urn:av-openhome-org:service:Time:1 urn:av-openhome-org:serviceId:Time /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Time-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Time-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Time-1 urn:av-openhome-org:service:Volume:1 urn:av-openhome-org:serviceId:Volume /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Volume-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Volume-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Volume-1 urn:av-openhome-org:service:Credentials:1 urn:av-openhome-org:serviceId:Credentials /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Credentials-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Credentials-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Credentials-1 urn:av-openhome-org:service:Playlist:1 urn:av-openhome-org:serviceId:Playlist /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Playlist-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Playlist-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Playlist-1 urn:av-openhome-org:service:Radio:1 urn:av-openhome-org:serviceId:Radio /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Radio-1.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Radio-1 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Radio-1 urn:av-openhome-org:service:Product:2 urn:av-openhome-org:serviceId:Product /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/urn-av-openhome-org-service-Product-2.xml /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/ctl-urn-av-openhome-org-service-Product-2 /uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/evt-urn-av-openhome-org-service-Product-2UPnP devices found : 2
Device #0: ID 0x0 mrendu-01EE43 UID: uuid:b74470f1-a552-9ec8-38a8-d063b401ee43 Location: http://10.0.0.61:49152/uuid-b74470f1-a552-9ec8-38a8-d063b401ee43/description.xml
Device #1: ID 0x0 Naim UID: uuid:5F9EC1B3-ED59-79BB-4530-0011F6A99B33 Location: http://10.0.0.67:8080/description.xml
Max. memory for audio buffers: 2464MB
Device #0: ID 0x31 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:114 UID: AppleHDAEngineOutput:1B,0,1,1:0
