Audirvana won't start
Today when I tried to start Audirvana i got the following error message:
Audirvana
The message says, translated from swedish:
The key cannot be used in the specified state
Audirvana worked yesterday and I haven’t done any changing on my system. I have tried to reinstall Audirvana, disconnect my computor but nothing works.
I am running Windows 11 Pro.
Hello @Gits,
Can you send us your audirvana.log and audirvana.dmp file at [email protected]?
to show AppData folder:
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-10-97fbc472-c603-9d90-91d0-1166d1d9f4b5
audirvana.log and audirvana.dmp file sent.
I confirm you the reception of the files, we will take a look a them as soon as possible.
I am getting the same error message and cannot open Audirvana studio: in English it says: “UhandledException: the data is invalid” And it won’t let me reinstall from your website (and it knows that the latest version is already on my computer). UPDATE: Cleared after I uninstalled and reinstalled AS. Now waiting for AS to load up all my 100,000+ tracks!
