Audirvāna won't sync to NAS
Windows version of Audirvana 3.5 will sync just fine to NAS. But Mac version of Audirvana Studio refuses to do so. Please help! MacOS 11.5.1. Mac mini 2018.
I posted about this issue weeks ago and got no response. Would someone please help me this time?
I have 6,000 albums. It syncs less than 1,000 and stops. The only way I can get it to “see” the other folders is to open them one at a time in Finder, wait for it to say “Syncing” and then finish, and then open up the next folder. Incredibly tedious.
I paid for a subscription and I hoped the latest 1.6 update would fix this, but it did not. If this can’t be fixed, I want my money back.
What kind NAS is it.
Is your share via SMB?
Do you know the SMB version number?
Here’s the Debug Info:
Audirvana Mac Version 1.6.0 (10600)
macOS 11.5.1 with 32768MB RAM
AUTO: /Volumes/music/
Library database path: /Users/mistercubmac/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 49366
IFI (BY AMR) IFI PRO IDSD
Model UID:iFi Pro iDSD:20B1:3009
UID:AppleUSBAudioEngine:iFi (by AMR):iFi Pro iDSD:000:1
Active Sample Rate: 96kHz
ID 0x67 iFi Pro iDSD
Manufacturer: iFi (by AMR)
Model Name: iFi (by AMR) iFi Pro iDSD
Model UID: iFi Pro iDSD:20B1:3009
UID: AppleUSBAudioEngine:iFi (by AMR):iFi Pro iDSD:000:1
MQA Decoder device
Stream ID 0x68 2 channels starting at 1
30 virtual formats:
40 physical formats
2 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 768kHz
Local devices found : 4
Device #0: ID 0x70 LG HDR 4K Manufacturer: Apple Inc. Model UID: AppleGFXHDA:0 UID: AppleGFXHDAEngineOutputDP:f803:0:{6D1E-7707-00073216} Model Name: Apple Inc. LG HDR 4K
Device #1: ID 0x58 CalDigit Thunderbolt 3 Audio Manufacturer: CalDigit, Inc. Model UID: CalDigit Thunderbolt 3 Audio:2188:6533 UID: AppleUSBAudioEngine:CalDigit, Inc.:CalDigit Thunderbolt 3 Audio:1200000:1 Model Name: CalDigit, Inc. CalDigit Thunderbolt 3 Audio
Device #2: ID 0x67 iFi Pro iDSD Manufacturer: iFi (by AMR) Model UID: iFi Pro iDSD:20B1:3009 UID: AppleUSBAudioEngine:iFi (by AMR):iFi Pro iDSD:000:1 Model Name: iFi (by AMR) iFi Pro iDSD
Device #3: ID 0x52 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice Model Name: Apple Inc. Mac mini Speakers
UPnP devices found : 6
Device #0: ID 0x0 Theater UID: uuid:01595793-7cb7-1357-0080-0005cd8f736b Location: http://192.168.50.152:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 [LG] webOS TV UH6030 UID: uuid:1adf2c89-e0eb-5566-f5f4-8af32586f7d0 Location: http://192.168.50.25:1665/
Device #2: ID 0x0 Theater UID: uuid:09532ab7-b066-14d9-0080-0005cd8f736b Location: http://192.168.50.152:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Theater UID: uuid:b94b674e-431f-1a8b-0080-0005cd8f736b Location: http://192.168.50.152:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Theater UID: uuid:2e091912-a8e3-b43e-8aa2-01b6029bda01 Location: http://192.168.50.152:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Theater UID: uuid:d3a0533a-d8a0-873a-9682-3a01338c4202 Location: http://192.168.50.152:60006/upnp/desc/aios_device/aios_device.xml
NAS = Synology DS918+
SMB version = ? How do I find this information?
In the Control Panel → FIle services → SMB select “Advanced Setting” and set the “Minimum SMB protocol” to “SMB2”.
Done. Now the synced number of albums is up to 930, one more before I increased the SMB minimum to v2. But it sticks there and does not sync any additional albums.
Try to unmount and remount the NAS share on your Mac.
Done. No change.
Then it’s something else. Check the folder names, maybe there are some special characters that Audirvana doesn’t like. There are threads about this in the community. Search a bit.
I have been going through my library and removing the characters that Audirvana doesn’t “like,” and haven’t made much progress. Funny how this program is so picky, while others like Roon have absolutely no problem with my library as-is. Just saying.
