Audivarna not playing hi-res tracks
Hi there,
So, I’m having a problem streaming hi-res audio via Qobuz on Audirvana on my macbook pro. It can handle CD quality streaming but anything higher and songs cut out repeatedly during playback. I’ve been streaming over wifi but I’ve also used a solid ethernet connection to see if that helps - and it doesn’t. Anyone have any ideas? Thanks in advance. I will post the logfile separately below.
Welcome…
Please paste your debug information report here, so folks can help the best possible…
It is found here: Settings → My Account → Help → Debug info
Hello
May be your internet connexion is too slow. Can you performe a benchmark to get your bandwidth.
Thanks, the benchmark test is attached.
Thanks, here it is:
Audirvana Studio 2.9.5 (20906)
macOS Version 14.3 (Build 23D56) x86_64 with 16GB physical RAM
Connected account of : Alex Doherty
	Per track: OFF
Sync list: 0 folders
Sort and display order: en
Library database path: /Users/alex2/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 69
Listening on on port 52365
UI theme: light
Font size: regular
My Music
Radios
Podcasts
Streaming
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Apple USB Ethernet Adapter
Preferred device: [UPnP] Mu-so Qb-B82A Model UID:Naim Audio Ltd. Mu-so Qb UID:uuid:5F9EC1B3-ED59-79BB-4530-E8C74F05B82A
Selected device:Mu-so Qb-B82A
Manufacturer: Naim Audio Ltd.
Model name: Mu-so Qb
Model UID: Naim Audio Ltd. Mu-so Qb
UID: uuid:5F9EC1B3-ED59-79BB-4530-E8C74F05B82A
UPnP device at http://192.168.0.69:8080/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
Unwanted playback stop workaround: Yes
http-get:
:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get:
:audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get:
:audio/wav:*
http-get::audio/x-mpegurl:
http-get:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
http-get::audio/x-aiff:
http-get::audio/x-m4a:
http-get::audio/x_pm_flac:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
20 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 24 big endian Signed Integer 88.2kHz
0 physical formats
NrTracks: 0
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.0.70:49153/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Play,Next,Previous
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001
	</pnpx:X_compatibleId>
pnpx:X_deviceCategory
MediaDevices
	</pnpx:X_deviceCategory>
pnpx:X_hardwareId
BridgecoCE2DM870_0xBD VEN_14E7&DEV_0001&REV_01
	</pnpx:X_hardwareId>
df:X_deviceCategory
Multimedia.DMR
	</df:X_deviceCategory>
Mu-so Qb-B82A
Naim Audio Ltd.
http://www.naimaudio.com
Naim Mu-so Qb all-in-one audio player
Mu-so Qb
20-004-0024
Mu-so 2nd Generation | The Premium Wireless Speaker Your Music Deserves | Naim Audio
E8C74F05B82A
123810928305
image/jpeg
48
48
24
/BCO_device_lrg_icon.jpg
image/png
120
120
24
/BCO_device_sm_icon.png
image/png
48
48
24
/BCO_device_lrg_icon.png
text/html
120
120
24
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/evt
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/evt
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/evt
http://192.168.0.69:80/1000/index.html
<X_Rhapsody-Extension>
urn:rhapsody-real-com:device-id-1-0:rdk_dev_2:E8C74F05B82A
</X_Rhapsody-Extension>
MediaDevices
pnpx:X_hardwareId
df:X_deviceCategory
Multimedia.DMR
Mu-so Qb-B82A
Naim Audio Ltd.
Mu-so Qb
20-004-0024
E8C74F05B82A
123810928305
image/jpeg
48
48
24
image/png
120
120
24
image/png
48
48
24
text/html
120
120
24
/AVTransport/ctrl
/AVTransport/evt
UPnP devices found : 1
Device #0: ID 0x0 : Mu-so Qb-B82A
Max. memory for audio buffers: 4112MB
Local Audio Engine: CoreAudio
Exclusive access: ON
Integer mode: ON
Use max I/O buffer size: OFF
Device #0: ID 0x68 MacBook Pro Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Chromecast devices found : 1
Device #0: Gia
Model name: Chromecast
Do you have problems with the Muso, or the Muso QB?
Hi, it’s the Muso QB (first generation).
That’s a known issue with the QB first gen. Unfortunately, that’s a Muso issue, not an Audirvana issue.
The best thing you can do is limit the output sample rate to 24 kHz and 96 Bits and see how that goes. If the stuttering remain, limit it to CD quality.
In all fairness: the difference between CD quality and 24 bit quality on the QB is pretty hard to spot.
ah ok. The strange thing is that the QB seems to be able to handle hi-res audio when it’s connected via my iphone and Mconnect. The problem when using the phone is not pauses and buffering during playback - instead the connection between my phone and the QB just drops out entirely. Whereas on my macbook the connection is solid - but it can’t handle hi-res at all.
You can try the options I have circled in the settings of the screenshot.
Thanks, I already tried those though :frowning:
