Please find Debug Info below:
macOS 10.14.6 with 32768MB RAM
Registered to Oleg Bely
AU plugin #0: None
AU plugin #1: Music Effect - FabFilter FF Pro-Q 3 ()
AU plugin #2: None
AU plugin #3: None
AUTO: /Users/oleg/Desktop/AUDIO/MUSIC
Library database path: /Users/oleg/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Built-in Output
Model UID:AppleHDA:92
UID:AppleHDAEngineOutput:1B,0,1,2:0
ID 0x30 Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:92 UID:AppleHDAEngineOutput:1B,0,1,2:0
Stream ID 0x31 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x30 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:92 UID: AppleHDAEngineOutput:1B,0,1,2:0
UPnP devices found : 2
Device #0: ID 0x0 Гостиная UID: uuid:3d62cbc4-32f8-4fbc-8618-60b606071375 Location: http://192.168.1.54:49152/description.xml
Device #1: ID 0x0 Arcam Solo Movie UID: uuid:140479c0-58f3-1cef-84bf-001b7c0528fc Location: http://192.168.1.237:2870/dmr.xml
