Hi there,
I recently added a Raspberry Pi connection to play local files. So far so good. However there is a strange issue that a couple of albums have gone missing from my Library. I only have 2 albums downloaded from Bandcamp (Flac 24 Bit). But they do not appear in my library on my Pi.
I also have my library on my iCloud to play on my MacBook. Those 2 albums are there in my library.
The 2 albums are on my Raspberry Pi hard drive (Seagate 1TB external) but don’t appear in the Library in Audirvana.
I contacted Bandcamp to see if there were any restrictions for use on multiple devices and they said no, it must be an Audirvana issue.
Any ideas?
If they are not locked Apple files, maybe they are in restricted folder that Audirvana can’t access…
Have you tried to copy those 2 CDs somewhere else, and see?
Can you try a manual sync?
In the remote app, go to the settings, the tab ‘local’ at the top of the screen.
Next to your local library link there is an arrow on the right hand side of the screen. If you click that arrow, a screen will pop up that looks like the one below. There you start a synchronisation by hand.
I have noticed that the synchronisation of the Core Player is a bit haphazard with larger libraries. I think there’s still work to do for Audirvana.
I tried moving to a seperate folder within my music folder but it still doesn’t read the albums. Very strange that my Mac can read the albums but not the Pi
Tried a manual synchronize but no joy
However on my Remote app on my phone and iPad, there is no ‘Local’ tab in Settings. I am running Audirvana Origin btw
