Okay, while you are playing this track, can you post your debug info again?
Audirvana Studio 1.7.2 (10702)
macOS Version 11.6 (assemblage 20G165) with 8GB physical RAM
Globally: ON
AUTO: /Users/srmac/Music/Qobuz
iTunes/Music library synchronization: last synchronized on Sat Oct 9 15:37:00 2021
Library database path: /Users/srmac/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 57894
Preferred device: MUSICAL FIDELITY M1 CLIC Model UID:Musical Fidelity M1 CliC UID:uuid:5F9EC1B3-FF59-19BB-8530-0011F68BAF3A
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.1.35:8080/description.xml
ID 0x0 M1 CliC
Manufacturer: Musical Fidelity
Model Name:
Model UID: Musical Fidelity M1 CliC
UID: uuid:5F9EC1B3-FF59-19BB-8530-0011F68BAF3A
5 available sample rates up to 192000Hz
Volume control: No
Avoid RAW PCM streams: Yes
http-get::audio/L16;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=192000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L16;rate=192000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=44100;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=48000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=96000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=88200;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=192000;channels=1:DLNA.ORG_PN=LPCM
http-get::audio/L24;rate=192000;channels=2:DLNA.ORG_PN=LPCM
http-get::audio/x-mpeg:
http-get::audio/mpeg:
http-get::audio/mpegurl:
http-get::audio/x-mpegurl:
http-get::audio/scpls:
http-get::audio/ms-wma:
http-get::audio/x-ms-wma:
http-get::application/octet-stream:
http-get::audio/x-ms-asf:
http-get::application/ogg:
http-get::audio/mp4:
http-get::audio/x-flac:
http-wavetunes::audio/x-ms-wma:
DLNA 1.5: Yes
Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
5 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 192kHz
0 physical formats
NrTracks: 1
MediaDuration: NOT_IMPLEMENTED
CurrentURI: http://192.168.1.84:49152/audirvana/audio_18.pcm
CurrentURIMetadata: dc:titleMy Way (Remastered 2008)</dc:title>upnp:artistFrank Sinatra</upnp:artist>upnp:albumUltimate Sinatra: The Centennial Collection</upnp:album>upnp:albumArtURIhttp://static.qobuz.com/images/covers/37/38/0060254733837_600.jpg</upnp:albumArtURI>http://192.168.1.84:49152/audirvana/audio_18.pcm
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PLAYING PAUSED_PLAYBACK TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string NETWORK RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string PossibleRecordStorageMedia string CurrentPlayMode string NORMAL NORMAL SHUFFLE REPEAT_ONE REPEAT_ALL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 MS_DigitalMediaDeviceClass_DMR_V001 Multimedia.DMR BridgecoCE2DM870_0xBD urn:schemas-upnp-org:device:MediaRenderer:1 M1 CliC Musical Fidelity http://www.musicalfidelity.com/ High End Streaming Client M1 CliC 1.0 http://www.musicalfidelity.com/ 0011F68BAF3A uuid:5F9EC1B3-FF59-19BB-8530-0011F68BAF3A 123810928305556upc image/jpeg 48 48 24 /BCO_device_sm_icon.jpg image/jpeg 120 120 24 /BCO_device_lrg_icon.jpg image/png 48 48 24 /BCO_device_sm_icon.png image/png 120 120 24 /BCO_device_lrg_icon.png urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl/desc.xml /RenderingControl/ctrl /RenderingControl/evt urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager/desc.xml /ConnectionManager/ctrl /ConnectionManager/evt urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport/desc.xml /AVTransport/ctrl /AVTransport/evt urn:schemas-dm-holdings-com:service:X_HtmlPageHandler:1 urn:schemas-dm-holdings-com:serviceId:X_HtmlPage /HtmlPageHandler/desc.xml /HtmlPageHandler/ctrl /HtmlPageHandler/evt urn:schemas-dm-holdings-com:service:X_WholeHomeAudio:1 urn:schemas-dm-holdings-com:serviceId:X_WholeHomeAudio:1 /WholeHomeAudio/desc.xml /WholeHomeAudio/ctrl /WholeHomeAudio/evt http://192.168.1.35UPnP devices found : 1
Device #0: ID 0x0 M1 CliC UID: uuid:5F9EC1B3-FF59-19BB-8530-0011F68BAF3A Location: http://192.168.1.35:8080/description.xml
Max. memory for audio buffers: 1868MB
Device #0: ID 0x32 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:54 UID: AppleHDAEngineOutput:1F,3,0,1,1:0 Model Name: Apple Inc. Sortie intégrée
Your device seems to not support wav signal which is probably why you see the output as it send the audio using pcm.
??? wav …my source is qobuz (streaming HI-res)with FLAC 24/44.1 khz …I don’t understand…
When you are using Audirvana with a UPNP device, the audio signal is sent in wav so it is not altered. Your device do not support it and send the audio signal in pcm so your device it’s not behaving as it should.
It can be a bug in their UPnP implementation, does your device is up to date?
yes is up to date…
Problem is when you are using Audirvana, the device itself announce it’s capabilities to our software. If their is a bug in their UPnP implementation (like it surely does here), we can’t do that much. You should contact your device manufacturer to talk about this with them. If you want you can add support@audirvana.com in cc of your mail so we can reply to question from them.
ok j’envoie desuite au support un mail…
merci
