Audirvana Mac Version 3.5.35 (3565)
macOS 10.11.6 with 4096MB RAM
Registered to JOSE BERMUDEZ
AU plugin #0: Effect - Voxengo Marvel GEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SW volume control: ON
Sync list: 2 folders
AUTO: /Users/perro1965/Music/HDtracks
AUTO: /Users/perro1965/Music/THE AUDIOPHILIAC MA RECORDINGS SAMPLER
Library database path: /Users/perro1965/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
HRA-Streaming: Login failed
Max. memory for audio buffers: 1056MB
USB Audio DAC
Model UID:USB Audio DAC :08BB:2704
UID:AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14100000:1
Device: 2ch Non-mixable linear PCM Interleaved 16bits little endian Signed Integer, 4 bytes per frame 48kHz
Active Sample Rate: 48kHz
Hog Mode is on
ID 0x26 USB Audio DAC Manufacturer:Burr-Brown from TI
Model UID:USB Audio DAC :08BB:2704 UID:AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14100000:1
3 available sample rates up to 48000Hz
32000
Stream ID 0x27 2 channels starting at 1
12 virtual formats:
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 48kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 44.1kHz
1 ch Mixable linear PCM Interleaved 32 little endian Signed Float 32kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Non-mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
12 physical formats
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 48kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 44.1kHz
1 ch Mixable linear PCM Interleaved 16 little endian Signed Integer 32kHz
Device #0: ID 0x37 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:82 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x26 USB Audio DAC Manufacturer: Burr-Brown from TI Model UID: USB Audio DAC :08BB:2704 UID: AppleUSBAudioEngine:Burr-Brown from TI :USB Audio DAC :14100000:1
