Bonjour,
Depuis que j’ai installé Audirvana version 3700 sur ma nouvelle machine sous Mojave, j’ai une erreur à chaque lancement d’Audirvana qui ne trouve pas le fichier bibliothèque dans Library/Application Support/Audirvana, alors que le fichier AudirvanaPlusDatabase.sqlite est bien présent sur mon disque dur système. J’ai essayé d’optimiser la base de données en reconstruisant les index et de défragmenter sans succès. Quand je lance la défragmentation, j’ai le message de fichier introuvable au redémarrage de l’application. Que faire ? Merci !
Start fresh Audirvana by deleting those files…
If you have Playlists that are important export them first to desktop and save them in a folder… when Audirvana is reset, you can re-import them back in one shot. Sadly to this day, the folders they were in if so, are not back, you have to do them again…
Go to Audirvana preferences menu and delete all your folder of databse in the window with the minus sign… so now, you have zero folder there…
Close Audirvana
Trash All the files in that folder (that is your database of music, back it up! or not)
trash com.audirvana.Audirvana-Plus.plist and com.audirvana.Audirvana.plist in that folder (those are Audiravana software preferences, back them up! or not). You will need your serial number after.
Restart MAC.
Open Audirvana, enter serial, choose a library folder for your music
at first it will sync in top middle of main window…
LET IT GO, even better don’t try to adjust windows or edit files, even playing music
while it is not finished… you’ll see the progress bar going… Could be long the first time
depending on how large your library is, and MAC is fast or not… go to sleep if it is too long
Then when finished, shut down Audirvana, yes close it before playing a song…
Now open it again, that way it will have save is database and setting before you make it crash maybe
You got brand new interface and new sound… Go to Audirvana menu and select preferences… look at them all, then click on speaker icon in the bottom right main window… select your DAC, then the arrow right of it and look at all the preferences there too… ready, click library icon on top right, click cover if you prefer covers over tracks mode… cmd + or - will make them bigger or smaller… click a cover to see it songs… do cmd i to see the info panel of that album, click a song and select them all with cmd A and do cmd i to see all their infos to be edited by you if needed… double click a song and listen, be happy
Sorry for the english text, too lazy to translate it in french
Mais je le peut si tu ne peux pas lire l’anglais
Great, it works! Thank you.
