Bonjour,
Que ce soit avec Tidal ou qobuz ou mon NAS, à chaque fois que je veux lire un morceau, j’ai un blocage sur: Chargement de la première piste…
J’ai la dernière version (3.5.42) sur Mac OS 11.0.1.
Merci d’avance.
macOS 10.16.0 with 65536MB RAM
Licence enregistrée pour Ludovic Raffin-Marchetti
AUTO: /Volumes/music/
Library database path: /Users/ludovicraffin-marchetti/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: LS50 Wireless II Ludovic Model UID:KEF LS50 Wireless II Ludovic UID:uuid:1134b900-7e4c-4052-8805-db59bb95a38f
UPnP device at http://192.168.1.26:39911/1134b900-7e4c-4052-8805-db59bb95a38f.xml
ID 0x0 LS50 Wireless II Ludovic Manufacturer:KEF
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/mpeg:
http-get::application/ogg:
http-get::audio/aiff:
http-get::audio/wave:
http-get::audio/x-flac:
http-get::audio/flac:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::text/xml:
http-get::audio/ogg:
http-get::audio/x-dsf:
http-get::audio/vorbis:
http-get::audio/m4a:
http-get::audio/wav:
http-get::audio/x-dff:
http-get::audio/x-aiff:
http-get::audio/aac:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-flac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aac:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
14 virtual formats:
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 LS50 Wireless II Ludovic KEF http://www.kef.com/ LS50 Wireless II LS50 Wireless II SP4025 http://www.kef.com/ b87dc613-198b-440f-afb3-261f6c4b9aff uuid:1134b900-7e4c-4052-8805-db59bb95a38f image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.26:80/ DMR-1.51UPnP devices found : 1
Device #0: ID 0x0 LS50 Wireless II Ludovic UID: uuid:1134b900-7e4c-4052-8805-db59bb95a38f Location: http://192.168.1.26:39911/1134b900-7e4c-4052-8805-db59bb95a38f.xml
Max. memory for audio buffers: 62464MB
Local devices found : 6
Device #0: ID 0x5c Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:16 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x37 MJAudioRecorder Manufacturer: MJ Audio Inc. Model UID: MJRecordDeviceModelUID UID: MJRecordDevice
Device #2: ID 0x40 Mixlr AudioLink Manufacturer: Mixlr Model UID: com_mixlr_driver_MixlrAudioDevice:Mixlr UID: MixlrAudioEngine:0
Device #3: ID 0x4b Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Device #4: ID 0x2e Audiojingle Manufacturer: Audiojingle x Software Model UID: Soundtree UID: com.audiojinglex.soundtree.mastereffect
Device #5: ID 0x33 Audiojingle (UI Sounds) Manufacturer: Audiojingle x Software Model UID: Soundtree_UISounds UID: com.audiojinglex.soundtree.mastereffect.UISounds
Reduce it to 4096MB and try again.
done but nothing change!
Try to restart Audrivana after the change. You can also power cycle the active speakers.
If it still doesn’t work, try with built-in audio output device.
Built-in audio work but my LS50 on the networks doesn’t work…
Hmm, try to reset the speaker and re-configure it from scratch. Make sure you’re running the latest firmware version.
how you reset the speaker in audirvana?
No, I mean the speaker itself.
Hello @ludoraff,
There are some UPnP bug in LS50, you should try to reset them and they should work again with Audirvana.
Hello, I reset the speakers and it work again. Thanks
bug again, are you sure the problem come from the speakers…
thx
Well, that’s the solution. You can also try to ask Kef about it. At least you have a workaround in the meantime.
Yes it is, we had multiple reports about it, we also contacted them but it seems that they don’t have fixed this issue.
