Bug on scrolling
My list of albums from Tidal look all janky and jump while scrolling.
I don’t know how or where to post the screen capture I took showing the bug…
Click the landscape photo box in the reply box as per attached screenshot. Add the file from your photos. Wait till it is loaded 100% and hit reply.
I wasn’t clear. By screen capture I meant video, not a screenshot.
No problem. I’m aware of that. If you are on a Mac your video is still in Photos, if not it will be in files. Click the first or last of those options and you will get there. :+1:
Pretty sure Windows will work the same.
The screenshot I provided is just to show you to click the little Landscape Button between the Parentheses and the smiley face. That give you the option to upload your video.
