Audirvana 3.5.40 with Cambridge Audio DacMagic Plus will not play music. Finds DAC and can change settings but immediately quits when you hit the play arrow. Anyone else using this DAC?
Can you paste the debug info here?
If you just double click a song it crashes too?
Yes, i do. This combination works fine .
Got it working. Installed the latest Cambridge 2.0 USB driver on the PC and set DAC to USB version 2.0 using their procedure of holding buttons in, powering on/off, etc. Thanks for responding.
