Audirvana does not play Flac 16/44.1 files. Is there a problem with the CA Edge NQ player? Roon worked flawlessly.
Hello @tlo,
Do you get an error while you try to play 16/44 tracks?
gives no error message, downloads the track but does not play it.
Audirvana Studio 1.14.0 (11400)
macOS 11.6.8 with 4GB physical RAM
Connected account of : ritva löf
Max allowed volume: 30.1794
AUTO: /Users/ritvalof/Dropbox/My Mac (ritva-Air)/Documents
iTunes/Music library synchronization: last synchronized on Wed Sep 7 13:46:18 2022
Library database path: /Users/ritvalof/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 61166
Preferred device: CAMBRIDGE AUDIO EDGE NQ (F0) Model UID:Cambridge Audio Edge NQ UID:uuid:c7275007-e4d3-461d-96af-77e41ee5e1f5
Currently playing to UPnP device at 24 bits 192kHz
UPnP device at http://192.168.100.41:8050/c7275007-e4d3-461d-96af-77e41ee5e1f5/description.xml
ID 0x0 Edge NQ (f0)
Manufacturer: Cambridge Audio
Model Name: Edge NQ
Model UID: Cambridge Audio Edge NQ
UID: uuid:c7275007-e4d3-461d-96af-77e41ee5e1f5
8 available sample rates up to 5644800Hz
5644800
Volume control: No
DSD capability: Raw DSD (MSB)
Avoid RAW PCM streams: No
http-get::audio/x-ms-wma:DLNA.ORG_PN=WMALSL
http-get::audio/mpeg:
http-get::audio/m4a:
http-get::audio/x-m4a:
http-get::audio/aac:
http-get::audio/wave:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/ation/ogg:
http-get::audio/ogg:
http-get::audio/vorbis:
http-get::audio/x-vorbis:
http-get::audio/dff:
http-get::audio/x-dff:
http-get::audio/dsf:
http-get::audio/x-dsf:
http-get::audio/:*
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: dB
18 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 43
MediaDuration: 0:04:00
CurrentURI: http://192.168.100.44:49152/audirvana/audio_50.wav
CurrentURIMetadata: NOT_IMPLEMENTED
nextURI: http://192.168.100.44:49152/audirvana/audio_51.wav
PlayMedium: NETWORK
<?xml version="1.0"?> 1 0 TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING STOPPED TransportStatus string OK PlaybackStorageMedium string NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 CurrentTrack ui4 0 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string TRACK_NR REL_TIME ABS_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActionsCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 urn:schemas-upnp-org:device:MediaRenderer:1 Edge NQ (f0) Cambridge Audio http://www.cambridgeaudio.com/ Edge NQ 3467 uuid:c7275007-e4d3-461d-96af-77e41ee5e1f5 00202ff0 image/png 48 48 8 /c7275007-e4d3-461d-96af-77e41ee5e1f5/CA-roundal-48x48.png image/jpeg 48 48 24 /c7275007-e4d3-461d-96af-77e41ee5e1f5/CA-roundal-48x48.jpg image/png 120 120 8 /c7275007-e4d3-461d-96af-77e41ee5e1f5/CA-roundal-120x120.png image/jpeg 120 120 24 /c7275007-e4d3-461d-96af-77e41ee5e1f5/CA-roundal-120x120.jpg urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /c7275007-e4d3-461d-96af-77e41ee5e1f5/RenderingControl/RenderingControl1.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/RenderingControl/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/RenderingControl/event urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /c7275007-e4d3-461d-96af-77e41ee5e1f5/ConnectionManager/ConnectionManager1.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/ConnectionManager/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/ConnectionManager/event urn:schemas-upnp-org:service:ContentDirectory:1 urn:upnp-org:serviceId:ContentDirectory /c7275007-e4d3-461d-96af-77e41ee5e1f5/ContentDirectory/ContentDirectory1.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/ContentDirectory/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/ContentDirectory/event urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /c7275007-e4d3-461d-96af-77e41ee5e1f5/AVTransport/AVTransport1.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/AVTransport/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/AVTransport/event urn:UuVol-com:service:UuVolControl:5 urn:UuVol-com:serviceId:UuVolControl /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaRadio/RecivaRadio.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaRadio/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaRadio/event urn:UuVol-com:service:PlaylistExtension:1 urn:UuVol-com:serviceId:PlaylistExtension /c7275007-e4d3-461d-96af-77e41ee5e1f5/UuPlaylist/Playlist.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/UuPlaylist/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/UuPlaylist/event urn:UuVol-com:service:UuVolSimpleRemote:1 urn:UuVol-com:serviceId:UuVolSimpleRemote /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaSimpleRemote/RecivaSimpleRemote.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaSimpleRemote/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/RecivaSimpleRemote/event urn:UuVol-com:service:StreamMagic6:1 urn:UuVol-com:serviceId:StreamMagic6 /c7275007-e4d3-461d-96af-77e41ee5e1f5/StreamMagic6/StreamMagic6.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/StreamMagic6/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/StreamMagic6/event urn:UuVol-com:service:SMSearch:1 urn:UuVol-com:serviceId:SMSearch /c7275007-e4d3-461d-96af-77e41ee5e1f5/SMSearch/SMSearch.xml /c7275007-e4d3-461d-96af-77e41ee5e1f5/SMSearch/invoke /c7275007-e4d3-461d-96af-77e41ee5e1f5/SMSearch/event DMR-1.50 M-DMP-1.50UPnP devices found : 1
Device #0: ID 0x0 Edge NQ (f0) UID: uuid:c7275007-e4d3-461d-96af-77e41ee5e1f5 Location: http://192.168.100.41:8050/c7275007-e4d3-461d-96af-77e41ee5e1f5/description.xml
Max. memory for audio buffers: 1024MB
Device #0: ID 0x32 Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:114 UID: AppleHDAEngineOutput:1B,0,1,1:0 Model Name: Apple Inc. Built-in Output
