Hi…i seem to have lost my wifi connection to my denon ceol9 audio device on windows 10 ?..It was working up until last month…Anyone any ideas how i can get it back ?..thank you.
How is your ceol n9 connected to the network? If in Wi-Fi check in the settings menu if you can connect it to your WiFi network
… and check how is your pc WiFi connection is defined in Windows 10, it should be Private (not Public)
When i try and play a track from audirvana on my computer over my wifi…it shows up on my denon ceol9 system but it doesnt play…I cant see what the problem is…thanks for your reply.
Hello @Robert_Meighan,
Can you check your firewall settings: In Settings > Update and Security > Windows Security > Firewall and Network Protection > Allow an application via a firewall, make sure that the file audirvanaplus.exe is allowed to access the network.
