Hi,
I need help. I can’t open anymore Audirvana.
Main window is not showing up. I’ve restarted, tried to reinstall, to trash prefs. Audirvana site is down too (is it related?).
When quitting app, error is as follow :
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [1681]
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.audirvana.Audirvana 0x00000001002ea7b1 0x100000000 + 3057585
1 com.audirvana.Audirvana 0x0000000100782629 0x100000000 + 7874089
2 com.audirvana.Audirvana 0x0000000100785f97 0x100000000 + 7888791
3 com.audirvana.Audirvana 0x0000000100433f5c 0x100000000 + 4407132
4 com.audirvana.Audirvana 0x0000000100244d67 0x100000000 + 2379111
5 com.apple.AppKit 0x00007fff2da745f3 -[NSApplication _docController:shouldTerminate:] + 88
6 com.apple.AppKit 0x00007fff2da744c8 __91-[NSDocumentController(NSInternal) _closeAllDocumentsWithDelegate:shouldTerminateSelector:]_block_invoke + 448
7 com.apple.AppKit 0x00007fff2da74182 -[NSDocumentController(NSInternal) _closeAllDocumentsWithDelegate:shouldTerminateSelector:] + 1187
8 com.apple.AppKit 0x00007fff2da73cb8 -[NSDocumentController(NSInternal) __closeAllDocumentsWithDelegate:shouldTerminateSelector:] + 291
9 com.apple.AppKit 0x00007fff2da738d7 -[NSApplication _shouldTerminate] + 975
10 com.apple.AppKit 0x00007fff2da60d63 -[NSApplication terminate:] + 740
11 com.apple.AppKit 0x00007fff2d9d57a7 -[NSApplication(NSResponder) sendAction:to:from:] + 299
12 com.apple.AppKit 0x00007fff2dae5f3e -[NSMenuItem _corePerformAction] + 312
13 com.apple.AppKit 0x00007fff2dae5cba -[NSCarbonMenuImpl performActionWithHighlightingForItemAtIndex:] + 106
14 com.apple.AppKit 0x00007fff2db36848 -[NSMenu performActionForItemAtIndex:] + 114
15 com.apple.AppKit 0x00007fff2db367cd -[NSMenu _internalPerformActionForItemAtIndex:] + 82
16 com.apple.AppKit 0x00007fff2db36617 -[NSCarbonMenuImpl _carbonCommandProcessEvent:handlerCallRef:] + 101
17 com.apple.AppKit 0x00007fff2dac6d30 NSSLMMenuEventHandler + 908
18 com.apple.HIToolbox 0x00007fff2f1268ff DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1254
19 com.apple.HIToolbox 0x00007fff2f125d8d SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 329
20 com.apple.HIToolbox 0x00007fff2f13b47e SendEventToEventTarget + 39
21 com.apple.HIToolbox 0x00007fff2f19b40b SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 368
22 com.apple.HIToolbox 0x00007fff2f1c2065 SendMenuCommandWithContextAndModifiers + 45
23 com.apple.HIToolbox 0x00007fff2f1c200d SendMenuItemSelectedEvent + 346
24 com.apple.HIToolbox 0x00007fff2f1c1e59 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 96
25 com.apple.HIToolbox 0x00007fff2f1c288e MenuSelectCore(MenuData*, Point, double, unsigned int, OpaqueMenuRef**, unsigned short*) + 603
26 com.apple.HIToolbox 0x00007fff2f1c2598 _HandleMenuSelection2 + 460
27 com.apple.AppKit 0x00007fff2d969c0d _NSHandleCarbonMenuEvent + 215
28 com.apple.AppKit 0x00007fff2d969a7a _DPSEventHandledByCarbon + 54
29 com.apple.AppKit 0x00007fff2d791eca -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2962
30 com.apple.AppKit 0x00007fff2d78358e -[NSApplication run] + 658
31 com.apple.AppKit 0x00007fff2d755396 NSApplicationMain + 777
32 libdyld.dylib 0x00007fff6a3f4cc9 start + 1
