hello, could someone help me read my music files on HD with my MacBookPro, connected with golden audio cable to Marantz ND8006, the system always downgrade the quality to CD quality when reading. I have rebooted the entire laptop several times, it always come back to CD quality when reading.
Please help ! thank you so much in advance, Alain
here is the info debug copy
macOS 10.13.6 with 16384MB RAM
Licence enregistrée pour BOKOBZA
SW volume control: ON
AUTO: /Volumes/GOLD MUSIC 2TO/MUSIC
iTunes/Music library synchronization: last synchronized on Thu Dec 16 16:38:03 2021
Library database path: /Users/alainbokobza/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Qobuz: Connected as Qobuz Hi-Fi Sublime
Exclusive access: Disabled
ND8006
Model UID:ND8006:154E:300A
UID:AppleUSBAudioEngine:D&M Holdings Inc.:ND8006:14440000:1
ID 0x40 Sortie intégrée Manufacturer:Apple Inc.
Model UID:AppleHDA:57 UID:AppleHDAEngineOutput:1F,3,0,1,1:0
3 available sample rates up to 96000Hz
Stream ID 0x41 2 channels starting at 1
3 virtual formats:
3 physical formats
Local devices found : 4
Device #0: ID 0x2f Aggregate-Audio-Device Manufacturer: Apple Inc. Model UID: Aggregate-Audio-Device UID: Aggregate-Audio-Device
Device #1: ID 0x40 Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:57 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #2: ID 0x64 ND8006 Manufacturer: D&M Holdings Inc. Model UID: ND8006:154E:300A UID: AppleUSBAudioEngine:D&M Holdings Inc.:ND8006:14440000:1
Device #3: ID 0x4a Dell USB Audio Manufacturer: DisplayLink Model UID: Dell USB Audio:17E9:6006 UID: AppleUSBAudioEngine:DisplayLink:Dell Universal Dock D6000:1808317399:3
UPnP devices found : 5
Device #0: ID 0x0 Marantz ND8006 UID: uuid:2a34363b-1678-142f-0080-0005cdf956d6 Location: http://10.0.0.2:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Marantz ND8006 UID: uuid:6c5b29b2-0409-1718-0080-0005cdf956d6 Location: http://10.0.0.2:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 Marantz ND8006 UID: uuid:08f09bd9-3e8d-1cae-0080-0005cdf956d6 Location: http://10.0.0.2:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 Marantz ND8006 UID: uuid:e99d1ca1-8b7d-0872-23cb-527290c97ded Location: http://10.0.0.2:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 Marantz ND8006 UID: uuid:5fd65117-1310-c2bd-4990-c598939509f7 Location: http://10.0.0.2:60006/upnp/desc/aios_device/aios_device.xml
