Hi,
Some songs of my playlist don’t seem to play for some reason. They do work when i reduce the bit depth from 24 to 16 bit but i other songs from the same album work with 24 bit which is odd.
I attached the debug info. It wouldn’t let me upload the log for some reason so i posted part of it below:
Audirvana Studio 1.9.0 (10900)
Windows 10 (19042) with 32GB physical RAM
Connected account of : Thomas blondl
Sync list: 0 folders
Library database path: C:\Users\Thomas\AppData\Local\Audirvana\Audirvana\AudirvanaDatabase.sqlite
Listening on 192.168.0.13 on port 36436
Preferred device: Hegel Tom Hegel H120 Model UID:Hegel Tom Hegel H120 UID:uuid:1d1a31c6-1dd2-11b2-9f85-9b11de79c2cb
UPnP device at http://192.168.0.2:38400/description.xml
Tom Hegel H120
Manufacturer: Hegel
Model Name:
Model UID: Hegel Tom Hegel H120
UID: uuid:1d1a31c6-1dd2-11b2-9f85-9b11de79c2cb
Volume control: No
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
NrTracks: 1
MediaDuration: 0:03:11.000
CurrentURI: http://192.168.0.13:49152/audirvana/audioTest.pcm
CurrentURIMetadata:
dc:titletestTitle</dc:title>
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions TransportState string STOPPED PAUSED_PLAYBACK PLAYING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED PlaybackStorageMedium string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK NONE RecordStorageMedium string NOT_IMPLEMENTED PossiblePlaybackStorageMedia string UNKNOWN CD-DA DVD-VIDEO HDD NETWORK PossibleRecordStorageMedia string NOT_IMPLEMENTED CurrentPlayMode string NORMAL SHUFFLE REPEAT_ONE REPEAT_TRACK REPEAT_ALL NORMAL TransportPlaySpeed string 1 RecordMediumWriteStatus string NOT_IMPLEMENTED CurrentRecordQualityMode string NOT_IMPLEMENTED PossibleRecordQualityModes string NOT_IMPLEMENTED NumberOfTracks ui4 0 1 CurrentTrack ui4 0 1 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 CurrentTransportActions string LastChange string A_ARG_TYPE_SeekMode string ABS_COUNT TRACK_NR REL_TIME A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 QPlay:2 urn:schemas-upnp-org:device:MediaRenderer:1 Tom Hegel H120 Hegel http://www.hegel.com H120 H120 1.0 http://www.hegel.com uuid:1d1a31c6-1dd2-11b2-9f85-9b11de79c2cb http://192.168.0.2 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /QPlay.xml /QPlay /QPlay/eventSub http://192.168.0.2:38400UPnP devices found : 1
Device #0Tom Hegel H120 UID: uuid:1d1a31c6-1dd2-11b2-9f85-9b11de79c2cb Location: http://192.168.0.2:38400/description.xml
Max. memory for audio buffers: 10102MB
Local Audio Engine: WASAPI
Device #0: Speakers / Headphones (Realtek Audio) Manufacturer: Microsoft Model UID: MMDEVAPI\AudioEndpoints UID: \?\SWD#MMDEVAPI#{0.0.0.00000000}.{0b7afc77-3a81-4c44-a4b0-e4cd538185d2}#{e6327cad-dcec-4949-ae8a-991e976a79d2} Model Name: Speakers / Headphones (Realtek Audio)
Log entries:
2021-12-28 13:28:21,465 [1] INFO Audirvana.App - ============= Started Logging, Audirvana 1.9.0 =============
2021-12-28 13:28:24,150 [5] DEBUG Audirvana.App - UPnP: Error obtaining device description from http://192.168.0.6:9080 – error = -107
2021-12-28 13:28:24,892 [9] DEBUG Audirvana.App - UPnP: Error obtaining device description from http://192.168.0.6:9080 – error = -107
2021-12-28 13:28:27,180 [16] DEBUG Audirvana.App - RemoteServer: Server started and advertised on port 36436
2021-12-28 13:29:16,892 [16] DEBUG Audirvana.App - Tidal getAlbumSimilarAlbums error: 404
2021-12-28 13:30:03,718 [1] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_1.wav on instance 0
2021-12-28 13:30:42,763 [5] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_1.wav on instance 0
2021-12-28 13:31:12,733 [10] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-12-28 13:31:52,488 [1] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_4.wav on instance 0
2021-12-28 13:31:53,439 [28] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_3.wav on instance 0
2021-12-28 13:32:06,329 [6] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:32:06,568 [6] DEBUG Audirvana.App - Tidal getAlbumSimilarAlbums error: 404
2021-12-28 13:32:07,465 [36] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:32:19,539 [28] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_4.wav on instance 0
2021-12-28 13:33:16,378 [16] DEBUG Audirvana.App - Tidal getArtistBio error: 404
2021-12-28 13:33:16,609 [16] DEBUG Audirvana.App - Tidal getArtistSimilarArtists error: 404
2021-12-28 13:33:29,673 [28] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_5.wav on instance 0
2021-12-28 13:33:29,826 [8] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-12-28 13:33:30,708 [18] DEBUG Audirvana.App - Fatal error reading audio file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInOWE5M2UyMjQxNDQ5MDk3MDVmMTA4YjRmOTRiMmYyNjNfNjAubXA0/0.flac?token=1640662412~NTRjMDRhODY5ODI0YjQyODU3M2U5NWExNDFhYjRmMDQ4NjdmNWMwMw== aborting loading at frame 3528000
2021-12-28 13:33:39,434 [1] DEBUG Audirvana.App - Error 501 starting UPnP playback
2021-12-28 13:33:40,101 [22] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-12-28 13:33:40,992 [18] DEBUG Audirvana.App - Error reading FLAC file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInOWE5M2UyMjQxNDQ5MDk3MDVmMTA4YjRmOTRiMmYyNjNfNjAubXA0/0.flac?token=1640662412~NTRjMDRhODY5ODI0YjQyODU3M2U5NWExNDFhYjRmMDQ4NjdmNWMwMw== : FLAC__STREAM_DECODER_ABORTED
2021-12-28 13:33:40,993 [18] DEBUG Audirvana.App - Fatal error reading audio file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInOWE5M2UyMjQxNDQ5MDk3MDVmMTA4YjRmOTRiMmYyNjNfNjAubXA0/0.flac?token=1640662412~NTRjMDRhODY5ODI0YjQyODU3M2U5NWExNDFhYjRmMDQ4NjdmNWMwMw== aborting loading at frame 4410000
2021-12-28 13:33:59,966 [27] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:34:00,200 [19] DEBUG Audirvana.App - Tidal getAlbumSimilarAlbums error: 404
2021-12-28 13:34:00,470 [4] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:34:23,234 [1] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_9.wav on instance 0
2021-12-28 13:38:00,379 [21] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_8.wav on instance 0
2021-12-28 13:38:05,207 [18] DEBUG Audirvana.App - Error reading FLAC file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInYTFhNjRkOGMyNjdjZTE0N2E2MWJhZDc1MDZkYjJmM2JfNjAubXA0/0.flac?token=1640662685~ZTk1MjJjZTVlMDMyNzc4ZDhiZjFlZGEwMDk4MzBhZDcwODZmY2E5Mw== : FLAC__STREAM_DECODER_ABORTED
2021-12-28 13:38:05,208 [18] DEBUG Audirvana.App - Fatal error reading audio file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInYTFhNjRkOGMyNjdjZTE0N2E2MWJhZDc1MDZkYjJmM2JfNjAubXA0/0.flac?token=1640662685~ZTk1MjJjZTVlMDMyNzc4ZDhiZjFlZGEwMDk4MzBhZDcwODZmY2E5Mw== aborting loading at frame 7224402
2021-12-28 13:38:06,702 [42] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_9.wav on instance 0
2021-12-28 13:38:08,398 [42] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_10.wav on instance 0
2021-12-28 13:38:38,371 [12] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-12-28 13:39:24,730 [41] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_12.wav on instance 0
2021-12-28 13:39:30,497 [27] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:39:31,039 [27] DEBUG Audirvana.App - Tidal getAlbumDescription error: 404
2021-12-28 13:39:31,131 [4] DEBUG Audirvana.App - Tidal getAlbumSimilarAlbums error: 404
2021-12-28 13:39:54,731 [8] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-12-28 13:40:03,402 [21] DEBUG Audirvana.App - UPnP Error 401 setting NextAVTransportURI to http://192.168.0.13:49152/audirvana/audio_14.wav on instance 0
2021-12-28 13:40:33,397 [8] DEBUG Audirvana.App - UPnP: error restarting playback when switching to next track
2021-12-28 13:40:55,941 [1] DEBUG Audirvana.App - Error 501 starting UPnP playback
2021-12-28 13:40:56,598 [22] DEBUG Audirvana.App - UPnP: Error 401 resetting NextAVTransportURI when stopping
2021-12-28 13:40:56,879 [37] DEBUG Audirvana.App - Fatal error reading audio file https://sp-pr-fa.audio.tidal.com/mediatracks/CAEaKRInOWE5M2UyMjQxNDQ5MDk3MDVmMTA4YjRmOTRiMmYyNjNfNjAubXA0/0.flac?token=1640662804~NDdhZGRlNjVkODVjZjY0OWQ4NjBhODY5ZWIxNGM2M2VmNzU4NDNmYw== aborting loading at frame 5733000
