I’m going to be moving and won’t be using Comcast as my provider. What do I need to change to play my music?
Hi @Jamesroy , should not be much to do but login using your new isp of your choice. Might be a good idea to log out of everything from your old Comcast isp right before you move to the new one.
how do I log in?
What version of Audirvāna are you using? You are posting in an odd topic area for your particular issue. Perhaps we can get you a screenshot of the proper procedure once we understand what you are using. I’m recalling that you are using a legacy version or maybe you have upgraded?
Don’t forget that you can connect with [email protected] and @Antoine can help you out directly. He’s a great guy to work with.
Nothing have to be changed, the login is not linked to your ISP provider, it’s linked to the software.
I’m using studio 2.5
