Hi there.
Enjoying a lot A+ & the remote
One thing (actually 2)
the same composer research on A+ on MacBook Pro return me correct result, while on the remote, the composer can still be seen, but strangely it return a (0) and give no album result when clicking it
One more thing, still with the Remote; while I’m on an artist list album, I only have the list view, not the grind one : am I missing something ? (turning thumb album view on pref. has no effect)
Thank you for your report about the Remote app, we will fix this bug in a a future update of the Remote app. About the thumb view you can only have this view when you are in a main view of the Remote like Local Library>Album. I understand your point about it and we will also improve this in a future update of the Remote app.
this bug is also reproduced with audirvana 3.5.43 on a PC.
: composer search works perfectly on the PC but not on the remote app on an Ipad. Composer are correctly displayed but none of their works is displayed.
