Thanks. Hopefully my credit card details aren’t buried in here…
Audirvana Mac Version 3.5.26 (3556)
macOS 10.14.6 with 32768MB RAM
Sync list: 0 folders
Library database path: /Users/justinalexander/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Built-in Output
Model UID:AppleHDA:130
UID:AppleHDAEngineOutput:1F,3,0,1,2:0
Hog Mode is on
ID 0x2d Built-in Output Manufacturer:Apple Inc.
Model UID:AppleHDA:130 UID:AppleHDAEngineOutput:1F,3,0,1,2:0
Stream ID 0x2e 2 channels starting at 1
4 virtual formats:
16 physical formats
Device #0: ID 0x2d Built-in Output Manufacturer: Apple Inc. Model UID: AppleHDA:130 UID: AppleHDAEngineOutput:1F,3,0,1,2:0
