Même problème avec Mac Os 13.6.1 Ventura. Les enceintes Sonos sont invisibles. Je peux les utiliser en Airplay, mais la qualité est meilleure si la musique est envoyée directement. Comment les faire apparaitre ?
J’ai recopié debug infi ici:
Audirvana Studio 2.6.0 (20600)
macOS 13.6.1 with 16GB physical RAM
Connected account of : Anne-Sophie Godfroy
No plugin active
Bandwidth at 0dB = 99.5%
Phase = 66%
Replay Gain: by album
Sync list: 2 folders
AUTO: /Users/annesophie/Music/iTunes AS
AUTO: /Users/annesophie/Music/Qobuz
Library database path: /Users/annesophie/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Tracks with no MBID: 3311
Listening on 127.0.0.1 on port 58933
Active method: UPnP
Preferred device: [UPnP] Pièce Principale Model UID:Yamaha Corporation RX-A860 UID:uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd
Selected device:Pièce Principale
Manufacturer: Yamaha Corporation
Model name: RX-A860
Model UID: Yamaha Corporation RX-A860
UID: uuid:9ab0c000-f668-11de-9976-00a0ded9ebcd
UPnP device at http://192.168.1.12:49154/MediaRenderer/desc.xml
ID 0x0
14 available sample rates up to 192000Hz
8000
11025
12000
16000
22050
24000
32000
Volume control: No
DSD capability: Raw DSD (msb)
UPnP set capabilities
Maximum PCM bitdepth set: 24
Maximum DSD rate set: Disabled
Avoid RAW PCM streams: No
http-get::audio/l16;channels=2;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=44100:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=48000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=32000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=88200:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=96000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=64000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=22050:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=24000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=16000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=11025:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=12000:dlna.org_pn=lpcm
http-get::audio/l16;channels=2;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16;channels=1;rate=8000:dlna.org_pn=lpcm
http-get::audio/l16:dlna.org_pn=lpcm
http-get::audio/mpeg:dlna.org_pn=mp3
http-get::audio/x-ms-wma:dlna.org_pn=wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmafull
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmabase
http-get::audio/x-ms-wma:dlna.org_pn=wmdrm_wmafull
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_192
http-get::audio/vnd.dlna.adts:dlna.org_pn=aac_adts_320
http-get::audio/mp4:dlna.org_pn=aac_iso
http-get::audio/mp4:dlna.org_pn=aac_iso_192
http-get::audio/mp4:dlna.org_pn=aac_iso_320
http-get::audio/3gpp:dlna.org_pn=aac_iso
http-get::audio/3gpp:dlna.org_pn=aac_iso_192
http-get::audio/3gpp:dlna.org_pn=aac_iso_320
http-get::audio/x-ms-wma:*
http-get::audio/x-flac:
http-get::audio/x-mpeg:
http-get::audio/x-aac:
http-get::audio/x-mp3:
http-get::audio/x-mp4:
http-get::audio/x-mpg:
http-get::audio/x-wav:
http-get::audio/aacp:
http-get::audio/aiff:
http-get::audio/x-aiff:
http-get::audio/flac:
http-get::audio/aac:
http-get::audio/m4a:
http-get::audio/mp3:
http-get::audio/dsd:
http-get::audio/x-dsd:
http-get::audio/x-dsf:
http-get::audio/x-dff:
http-get::audio/wav:
DLNA 1.5: Yes
Native Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
Volume Control: scalar
24 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 32kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 88.2kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 96kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 64kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 22.05kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 24kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 16kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 11.025kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 12kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 8kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:05:46
CurrentURI: http://192.168.1.18:49152/audirvana/audioTest.pcm
CurrentURIMetadata: dc:titletestTitle</dc:title> upnp:classobject.item.audioItem.musicTrack</upnp:class> http://192.168.1.18:49152/audirvana/audioTest.pcm
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Stop,Play
<?xml version="1.0"?>
1
0
DMR-1.50
Pièce Principale
Yamaha Corporation
http://www.yamaha.com/
AV Receiver
RX-A860
A860
06ED71A3
image/jpeg
48
48
24
/Icons/48x48.jpg
image/jpeg
120
120
24
/Icons/120x120.jpg
image/png
48
48
24
/Icons/48x48.png
image/png
120
120
24
/Icons/120x120.png
/AVTransport/desc.xml
/AVTransport/ctrl
/AVTransport/event
/RenderingControl/desc.xml
/RenderingControl/ctrl
/RenderingControl/event
/ConnectionManager/desc.xml
/ConnectionManager/ctrl
/ConnectionManager/event
http://192.168.1.12/
http://192.168.1.12:80/
urn:schemas-yamaha-com:service:X_YamahaRemoteControl:1
/YamahaRemoteControl/ctrl
/YamahaRemoteControl/desc.xml
urn:schemas-yamaha-com:service:X_YamahaExtendedControl:1
/YamahaExtendedControl/v1/
1925
1
0
DMR-1.50
Pièce Principale
Yamaha Corporation
AV Receiver
RX-A860
A860
06ED71A3
image/jpeg
48
48
24
/Icons/48x48.jpg
image/jpeg
120
120
24
/Icons/120x120.jpg
image/png
48
48
24
/Icons/48x48.png
image/png
120
120
24
/Icons/120x120.png
/AVTransport/ctrl
/AVTransport/event
1925
UPnP devices found : 2
Device #0: ID 0x0 : Pièce Principale
Location: http://192.168.1.12:49154/MediaRenderer/desc.xml
Model name: RX-A860
Device #1: ID 0x0 : décodeur TV 4
UID: uuid:00ababad-7947-1048-8a00-247f20ecfe70
Manufacturer: SoftAtHome
Model name: SoftAtHome Media Renderer
Local Audio Engine: CoreAudio
Local devices found : 4
Device #0: ID 0x5a Sortie intégrée
Model UID: AppleHDA:54
UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Model name: Apple Inc. Sortie intégrée
Device #1: ID 0xa7 Audio du moniteur
Model UID: Display Audio:05AC:2912
UID: AppleUSBAudioEngine:Apple Inc.:Display Audio:14534100:2,1
USB Vendor ID: 0x05ac
USB Product ID: 0x2912
Model name: Apple Inc. Audio du moniteur
Device #2: ID 0xb0 USB PnP Audio Device
Manufacturer: Unknown Manufacturer
Model UID: USB PnP Audio Device:0C76:161F
UID: AppleUSBAudioEngine:Unknown Manufacturer:USB PnP Audio Device:14541000:1
USB Vendor ID: 0x0c76
USB Product ID: 0x161f
Model name: Unknown Manufacturer USB PnP Audio Device
Device #3: ID 0x36 Microsoft Teams Audio
Manufacturer: Microsoft Corp.
