Copy playlist contents to USB flash drive
Is there a preferred workflow in Studio (2.9.3, trial version) to copy the contents (the actual music files, not just metadata) of a playlist or playing queue to a USB flash drive in Windows 11? Thanks!
Hi @pinetreeln,
If I understand correctly, you would like to export a playlist with the actual files contained in this playlist?
Only possible with local files I think. This is going to be a bombshell if a streaming service would allow this.
For example: Qobuz let’s you download files for offline use. But those files will always stay in their environment. If one could export those files to a flashdrive, then all hell would break loose. That way illegal reproduction could fly sky high.
Yes, as a convenient way to build a flash drive for use in my car.
Hi @pinetreeln,
There is no option to do this. You must export the playlist and recreate the same folder structure in the playlist track path on your flash drive, and you should be good.
Thank you, Antoine and @Amarok1969!
