Hello out there, can anyone help? Transfer my songs from the MacBook Pro / Mac OS Catalina via Bluetooth, the receiver is a Sony STR-DH 590. So far it was flawless, new is an unpleasant sound between all songs, a hiss or crack. Can I fix this through settings?
Hello @Michael, Can you send me a copy of the “Debug Info”? You can get it in Audirvana Settings>General>Debug Info
Hello Damien, thank you for support. Here below the debug info. Played with audio settings, have the impression problem only appears with upsampling and SoX algorithm.
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 8192MB RAM
Registriert nach Michael Jeschke
Per track: OFF
AU plugin #0: Effect - Sonimus SonEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 3 folders
AUTO: /Users/michaeljeschke/Music/Amazon Music
AUTO: /Users/michaeljeschke/Music/Qobuz
Manual: (OFFLINE) /Volumes/Micha2/Music
Library database path: /Users/michaeljeschke/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 3918MB
STR-DH590
Model UID:94 4c60
UID:f8-a2-d6-0c-c7-3c:output
Active Sample Rate: 48kHz
ID 0x39 STR-DH590 Manufacturer:94
Model UID:94 4c60 UID:f8-a2-d6-0c-c7-3c:output
1 available sample rates up to 48000Hz
Audio buffer frame size : 15 to 3840 frames
Stream ID 0x3a 2 channels starting at 1
1 virtual formats:
1 physical formats
Device #0: ID 0x2f Ausgang (integriert) Manufacturer: Apple Inc. Model UID: AppleHDA:51 UID: AppleHDAEngineOutput:1F,3,0,1,1:0
Device #1: ID 0x39 STR-DH590 Manufacturer: 94 Model UID: 94 4c60 UID: f8-a2-d6-0c-c7-3c:output
Have you tried with power of 2 in the upsampling settings? in fact the settings you put may push a little bit too hard your DAC
Hello Damian, your answer came pretty fast, thanx. I changed the settings to “user-defined”. Now it works without disturbing scratch/crack sound. The other settings including “power of two” have not been helpful. Here the new parameters
Per track: OFF
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
SoX
CoreAudio audio path, buffer I/O frame size: 2048
STR-DH590
Model UID:94 4c60
Device: 2ch Mixable linear PCM Interleaved 32bits little endian Signed Float, 8 bytes per frame 48kHz
Hog Mode is on
ID 0x3e STR-DH590 Manufacturer:94
Current I/O buffer frame size : 2048
Stream ID 0x3f 2 channels starting at 1
1 virtual formats:
1 physical formats
Device #1: ID 0x3e STR-DH590 Manufacturer: 94 Model UID: 94 4c60 UID: f8-a2-d6-0c-c7-3c:output
Hi Damien
Apologies for the trouble but I have been having similar issues although mine is a brand new 2020 iMac connected to Topping D70 DAC via USB. The clicking and scratching sounds are continuous and renders my system unlistenable.
Regards
Shekhar
Hi Damien
I seem to have sorted the problem by combing through some old queries on the topic.
Please disregard my earlier message.
Regards
Shekhar
