I am getting a crackle noise L/R channels. Seems like only in the higher Freq. Just notice this on a DSD album
MacOS
MP
I try anything if I have a good reason. Why turn if off?
I got volume issues as it is. 250 WPC amp with 125 WPC speakers. Sometimes I have to push 70 on the volume bar to get a good volume, not loud. That I totally don’t understand.
Not an expert on that, but ain’t DSD have to be played at 100% Volume ?
I have no idea.
If I did turn it up to 100% if would be to loud.
Trying to figure out where I live in this digital world of audio.
Iv’e got good back end equipment. This front end stuff is a nightmare.
Thanks for your input.
my DAC has a volume control and a remote,
so i don’t use the volume control in Audirvana
Interesting, mine work in unison. Using a remote I can volume up, playback, or stop current track from playing.
i think mine is like a preamp dac thing, so it has a volume control ??
Wyred 4 Sound DAC 2 DSDse
The DAC is built in on the Hegal 390. It’s a good DAC. Has ethernet and USB. Needs a streamer for the USB for the higher Res. playback.
Deactivate Volume leveling as @RunHomeSlow suggests and Volume Control…
What you are probably getting are ISP’s (Inter Sample Peaks) that precipitate clipping distortion related to the Normalization process of volume leveling… Use your amp’s volume control…
Please paste your debug information here so folks can help the best possible… It is found here: Settings → My Account → Help → Debug info
I use volume levelling, but no software volume control… never a clipping issue.
Audirvana Origin 2.5.13 (20513)
macOS 14.6.1 with 8GB physical RAM
Connected account of :
Replay Gain: by track
Sync list: 5 folders
AUTO: /Volumes/2xDSD_MUSIC/
AUTO: /Volumes/16BIT_MUSIC/
AUTO: /Volumes/24BIT_MUSIC/
AUTO: /Volumes/DSD_MUSIC/
AUTO: /Volumes/U16BIT_MUSIC/
Library database path: /Users/masonsmacmini/Library/Application Support/Audirvana/AudirvanaDatabase.sqlite
Listening on 127.0.0.1 on port 56263
Font size: regular
Language: English
My Music
Library
Startup view: Library: Albums
Use Apple Remote: yes
Number of paired remotes: 0
Screen saver disabled: no
Active method: UPnP
Preferred device: [UPnP] H390D44134 Model UID:Hegel H390 UID:uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
Selected device:H390D44134
Manufacturer: Hegel
Model name: H390
Model UID: Hegel H390
UID: uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da
UPnP device at http://192.168.10.128:38400/description.xml
ID 0x0
Volume control: Yes
UPnP set capabilities
Maximum PCM bitdepth set: 24
Not native DSD capable
Avoid RAW PCM streams: No
http-get::audio/flac:
http-get::audio/x-flac:
http-get::audio/wav:
http-get::audio/x-wav:
http-get::application/ogg:
DLNA 1.5: Yes
Native Gapless playback: No
Missing events workaround: No
Can play native DSD: No
Volume Control: scalar
14 virtual formats:
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 44.1kHz
2 ch Non-mixable linear PCM Interleaved 16 big endian Signed Integer 48kHz
0 physical formats
NrTracks: 1
MediaDuration: 0:03:36.000
CurrentURI: http://192.168.10.118:49152/audirvana/audio_f_35.wav
CurrentURIMetadata:
dc:titleShe Hates Me</dc:title>
dc:creatorPuddle Of Mudd</dc:creator>
upnp:artistPuddle Of Mudd</upnp:artist>
<upnp:author role=“Composer”>Jimmy Stewart</upnp:author>
upnp:genreRock</upnp:genre>
upnp:albumArtURIhttp://192.168.10.118:49152/audirvana/artwork_0_35.jpg</upnp:albumArtURI>
upnp:albumCome Clean</upnp:album>
upnp:originalTrackNumber6</upnp:originalTrackNumber>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Current transport actions:
Pause,Stop,Seek,X_DLNA_SeekTime
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400Current device RootDevice description:
<?xml version="1.0"?> 1 0 DMR-1.50 urn:schemas-upnp-org:device:MediaRenderer:1 H390D44134 Hegel http://www.hegel.com H390 H390 1.0 http://www.hegel.com uuid:1ca16aa2-1dd2-11b2-9010-4d0e2579d3da http://192.168.10.128 urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /RenderingControl.xml /RenderingControl /RenderingControl/eventSub urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /AVTransport.xml /AVTransport /AVTransport/eventSub urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /ConnectionManager.xml /ConnectionManager /ConnectionManager/eventSub http://192.168.10.128:38400UPnP devices found : 1
Device #0: ID 0x0 : H390D44134
Manufacturer: Hegel
Model name: H390
Local Audio Engine: CoreAudio
Device #0: ID 0x32 LG FULL HD
Manufacturer: GSM
Model UID: 1E6D555B-0000-0000-011A-010380301B78
Model name: GSM LG FULL HD
Device #1: ID 0x58 Mac mini Speakers
Model UID: Speaker
UID: BuiltInSpeakerDevice
Are you using volume leveling in the context of DSD playback where the DAC does not support DSD and all DSD files are being down-converted/decimated to PCM 24/176.4kHz?
So what happens when you deactivate volume leveling when playing DSD files?
No.
Wondering about the physical layout of the network between the player host, an Apple computer running Audirvana and the UPNP device the Hegel H390… Wifi or Ethernet, routers, bridges, modems, etc?
Could this be from packet loss/retry across the network?
Also if I am reading this correctly, out of 8GB of RAM you are allocating ~5GB for audio buffers? Mabe try 1GB or 2GB for the buffers…
The lack of available System RAM as you point out, in concert with the decimation processing of DSD → PCM 24/176.4kHz and the normalization processing (volume leveling) on the result of the DSD decimation process, which adds 6dB of gain as seen here in the debug report:
Mac to the router, static IP for H390. NAS is home for the music files. All ethernet connections. Cat 6 cable.
So I lower the buffer to 2 GB. Took out volume control. This is what I got.
I do really appreciate all the help.
Font size: regular
Language: English
My Music
Library
Active method: UPnP
Currently playing to UPnP device at 24 bits 176.4kHz
Manufacturer: Hegel
Model name: H390
ID 0x0
Volume control: Yes
DLNA 1.5: Yes
14 virtual formats:
0 physical formats
NrTracks: 1
MediaDuration: 0:04:29.000
CurrentURI: http://192.168.10.118:49152/audirvana/audio_f_74.wav
CurrentURIMetadata:
dc:titleAiregin</dc:title>
dc:creatorWes Montgomery</dc:creator>
upnp:artistWes Montgomery</upnp:artist>
upnp:genreJazz</upnp:genre>
upnp:albumArtURIhttp://192.168.10.118:49152/audirvana/artwork_0_74.jpg</upnp:albumArtURI>
upnp:albumThe Incredible Guitar of Wes Montgomery [DSD]</upnp:album>
nextURI:
nextURIMetadata:
PlayMedium: NETWORK
Manufacturer: Hegel
Model name: H390
Max. memory for audio buffers: 2018MB
Manufacturer: GSM
Model UID: Speaker
Can you try playing with those prefs? or this is why maybe you have sound between songs
