Bonjour Damien,
merci de prendre un peu de temps pour vous pencher sur ce problème…
Voici donc les infos de debug (même problème avec ou sans SonEQ):
Audirvana Mac Version 3.5.29 (3559)
macOS 10.15.2 with 16384MB RAM
Licence enregistrée pour Vincent Tournier
AU plugin #0: Effect - Sonimus SonEQ ()
AU plugin #1: None
AU plugin #2: None
AU plugin #3: None
Sync list: 28 folders
AUTO: /Volumes/Zique/Alanis Morissette/Flac -Jagged Little Pill
AUTO: /Volumes/Zique/Barry White
AUTO: /Volumes/Zique/Blue Öyster Cult
AUTO: /Volumes/Zique/Bob Berg
AUTO: /Volumes/Zique/Buena Vista Social Club
AUTO: /Volumes/Zique/Classique/Bach Johann Sebastian
AUTO: /Volumes/Zique/Classique/Mozart Wolfgang Amadeus
AUTO: /Volumes/Zique/Diana Krall
AUTO: /Volumes/Zique/Doobie Brothers
AUTO: /Volumes/Zique/Eagles
AUTO: /Volumes/Zique/Emerson, Lake & Palmer
AUTO: /Volumes/Zique/Genesis/Steve Hackett
AUTO: /Volumes/Zique/John Lee Hooker
AUTO: /Volumes/Zique/Keith Richards
AUTO: /Volumes/Zique/Kenny Rogers
AUTO: /Volumes/Zique/Men at Work
AUTO: /Volumes/Zique/Neil Young
AUTO: /Volumes/Zique/Oasis
AUTO: /Volumes/Zique/Orchestral Manoeuvres In The Dark
AUTO: /Volumes/Zique/Paco de Lucía
AUTO: /Volumes/Zique/Peter Gabriel
AUTO: /Volumes/Zique/Pink Floyd/Pink Floyd-Flac Discography
AUTO: /Volumes/Zique/Stephen Stills
AUTO: /Volumes/Zique/Stevie Wonder
AUTO: /Volumes/Zique/Talking Heads
AUTO: /Volumes/Zique/The Beach Boys
AUTO: /Volumes/Zique/The Rolling Stones
AUTO: /Volumes/Zique/Variété francaise/Jean-Luc Ponty
iTunes/Music library synchronization: last synchronized on Sun Dec 1 09:16:26 2019
Library database path: /Users/vincent/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 12746MB
ATOLL USB Audio 2.0
Model UID:ATOLL USB Audio 2.0:20B1:0002
UID:AppleUSBAudioEngine:ATOLL :ATOLL USB Audio 2.0:0000:1,2
ID 0x29 ATOLL USB Audio 2.0 Manufacturer:ATOLL
Model UID:ATOLL USB Audio 2.0:20B1:0002 UID:AppleUSBAudioEngine:ATOLL :ATOLL USB Audio 2.0:0000:1,2
12 virtual formats:
12 physical formats
Local devices found : 3
Device #0: ID 0x4c Sortie intégrée Manufacturer: Apple Inc. Model UID: AppleHDA:94 UID: AppleHDAEngineOutput:1B,0,1,1:0
Device #1: ID 0x29 ATOLL USB Audio 2.0 Manufacturer: ATOLL Model UID: ATOLL USB Audio 2.0:20B1:0002 UID: AppleUSBAudioEngine:ATOLL :ATOLL USB Audio 2.0:0000:1,2
Device #2: ID 0x3a Soundflower (2ch) Manufacturer: ma++ ingalls for Cycling '74 Model UID: com_cycling74_driver_SoundflowerDevice:Soundflower UID: SoundflowerEngine:0
Bien cordialement,
Vincent
