I’m having problems with both getting the program (Audirvana 3.5, Windows 10 64 Bit) to scan the library at startup AND once running it crashes when the album library is scrolled by grabbing the scroll bar with the left mouse button and dragging down.
Firstly, I can only get the program to scan library on startup if I switch back and forth between album and artists view (this is a newly installed Audirvana 3.5 on a new PC - I did not have either of these issues on the old PC).
Secondly, the more fatal error, when manual scrolling as described above the program will crash with the following errors (from Audirvana.log):
2021-07-12 19:38:03,400 [1] FATAL Audirvana.App -
2021-07-12 19:38:03,416 [1] FATAL Audirvana.App - ============= UnhandledException =============
2021-07-12 19:38:03,416 [1] FATAL Audirvana.App - System.IndexOutOfRangeException: Index was outside the bounds of the array.
at System.Collections.Generic.Dictionary`2.Insert(TKey key, TValue value, Boolean add)
at Audirvana.Data.AlbumsCollection.get_Item(Int32 index)
at System.Windows.Controls.ItemContainerGenerator.Generator.GenerateNext(Boolean stopAtRealized, Boolean& isNewlyRealized)
at Audirvana.Controls.VirtualizingWrapPanel.MeasureOverride(Size availableSize)
at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
at System.Windows.UIElement.Measure(Size availableSize)
See screenshot:
