Hello,
the programm crashed if you are using JPlay and DSD. JPlay without DSD works fine. Jplay and DSD with Foobar works fine.
BR
Josef
Hello,
BR
Josef
Hello,
Thanks for this report.
How do you play to JPlay? UPnP? ASIO ?
Hi,
My Audirvana stopped to work with jplay ASIO Driver on the middle of December (after six months of fluent co-operation). One day everything was OK and next day communicate “Error starting device” appeared. I reinstaled both jplay and Audirvana but nothig happened. Have you any idea what is the reason? All settings in both applications seems to be OK.
Regards,
Andrzej
Hello @Andkamly,
Jplay maybe made an update of the Asio driver and it may introduced a bug in it. Have you contacted Jplay support for your issue?
