My music files are on an external HDD - I now have two entries in the Audirvana library, one greyed out as unavailable, one active - ie: all tracks duplicated (see screen shot). All these files play in sequence. When I deleted the libraries, the greyed out files remained, and they could all be played. This is bizarre. Rescanning, resyncing, rebooting, etc. do not fix the problem. Any solution?
Yes: 3.5.38.
Here’s the debug info, if it helps.
macOS 10.15.5 with 16384MB RAM
Registered to Gregory F Burgess
Sync list: 2 folders
AUTO: /Volumes/4TB SSD/Music/Digital Audio
AUTO: /Users/gburgess/Music/DSD Audio
Library database path: /Users/gburgess/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Max. memory for audio buffers: 15360MB
Integer mode: Disabled
Qutest
Model UID:Qutest:245F:0815
UID:AppleUSBAudioEngine:Chord Electronics Ltd:Qutest:413-001:2
Active Sample Rate: 96kHz
ID 0x4f Qutest Manufacturer:Chord Electronics Ltd
Model UID:Qutest:245F:0815 UID:AppleUSBAudioEngine:Chord Electronics Ltd:Qutest:413-001:2
11 available sample rates up to 768000Hz
32000
Stream ID 0x50 2 channels starting at 1
22 virtual formats:
22 physical formats
Device #0: ID 0x4f Qutest Manufacturer: Chord Electronics Ltd Model UID: Qutest:245F:0815 UID: AppleUSBAudioEngine:Chord Electronics Ltd:Qutest:413-001:2
Device #1: ID 0x49 Mac mini Speakers Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice
UPnP devices found : 5
Device #0: ID 0x0 HEOS Link UID: uuid:04fc3439-441c-1bd1-0080-0005cde21752 Location: http://10.1.1.30:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 HEOS Link UID: uuid:c26e55dd-e8a0-18f8-0080-0005cde21752 Location: http://10.1.1.30:60006/upnp/desc/aios_device/aios_device.xml
Device #2: ID 0x0 HEOS Link UID: uuid:301913d1-702e-19b7-0080-0005cde21752 Location: http://10.1.1.30:60006/upnp/desc/aios_device/aios_device.xml
Device #3: ID 0x0 HEOS Link UID: uuid:26d025ea-cc75-eef5-96ea-37cdfb8099fe Location: http://10.1.1.30:60006/upnp/desc/aios_device/aios_device.xml
Device #4: ID 0x0 HEOS Link UID: uuid:a0eb5dfb-d23d-d8aa-3871-662e44b7746c Location: http://10.1.1.30:60006/upnp/desc/aios_device/aios_device.xml
Same stuff here, got a few albums that appears twice in the library, once greyed out and once “normally”…
Yes, I’ve done that. The problem remains.
Somehow, the library file has been corrupted in one way or another (as is usually the case with duplicates). I removed the current folder and, just to see what would happen, I synced to my NAS, which I use for backup. After syncing, all albums were duplicated (one active, one greyed). The only option was to delete the library file and sync monitored folders again to rebuild it (not something I’d like to do, with over 2TB of audio files to sync, and the loss of playlists). Now, when the SSD is ejected, all audio files are greyed; when remounted, they are white (with no greyed duplicates).
Thanks for looking at this. And keep up the fine work with Audirvana. But the audio library is delicate creature and needs to be treated with much tenderness. If only there were some way of troubleshooting and/or editing it.
Hello @gfburgess, unfortunately you will have to delete the database as the duplicates will still remain if you don’t do that as they are memorized by the database.
