DAC over USB on QNAP?
Hi,
think about to buy an QNAP …
so, did I understand that correctly?
Install the Audirvana .qpkg on a QNAP,
connect a DAC over USB on a QNAP USB port,
( have a ifi zen dAC )
and Audirvana see the DAC, so I can use it with
the Audirvana Remote App?
Will use the Audio out form the DAC, but there some QNAPs
with Audio out, can I use the Audio out form the QNAP too?
thanks
