Debug Info not showing
When opening “Debug Info” I get an “unhandled exception”
ScreenHunter_05 Nov. 11 20.10
Audirvana Studio 1.8
Windows 10 (19043)
The info is there though, you can paste it manually in notepad.
Hello @Slainte,
Do you have the same issue with the 1.8.1 version?
I can report I have the same issue too with version 1.8.1 on Windows 11.
Can you send me your audirvana.dmp and audirvana.log file at support@audirvana.com?
to show AppData folder:
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-10-97fbc472-c603-9d90-91d0-1166d1d9f4b5
Hi @Antoine, Audirvana does not crash and therefore does not generate a *.dmp file. It shows the error message, but still works after closing the error message. The last Audirvana.dmp file I found is of a couple of weeks ago, which is not of much use.
Also, after this error message I can still paste the debug information in a text file, so it is not a big deal, because everything still works (Audirvana does not crash and copying and pasting the debug info works). It is only strange that this exception error shows. But no serious problem at all…
