Bonjour Damien, depuis quelques jours, de plus en plus de morceaux ne sont pas lus complètement et changent brusquement avant la fin.
D’autre par, depuis hier, le délai d’ouverture de l’application sur Mac est très longue, environ 8 à 10 secondes.
macOS 11.1.0 with 16384MB RAM
Licence enregistrée pour Alain Westermann
Per track: OFF
Phase = 73
Replay Gain: by album
AUTO: /Volumes/Alain 1 Audirvana/
Library database path: /Users/alainwestermann/Library/Application Support/Audirvana/AudirvanaPlusDatabaseV2.sqlite
Preferred device: LS50 Wireless II Model UID:KEF LS50 Wireless II UID:uuid:ab707cf6-f37b-49a6-b8b2-e74c5b39100d
UPnP device at http://192.168.1.17:38111/ab707cf6-f37b-49a6-b8b2-e74c5b39100d.xml
ID 0x0 LS50 Wireless II Manufacturer:KEF
Volume control: No
DSD capability: Raw DSD (MSB)
http-get::audio/flac:
http-get::audio/x-dsf:
http-get::audio/ogg:
http-get::audio/x-dff:
http-get::audio/m4a:
http-get::audio/wav:
http-get::application/ogg:
http-get::text/xml:
http-get::audio/aac:
http-get::audio/vorbis:
http-get::audio/x-aiff:
http-get::audio/mpeg:
http-get::audio/aiff:
http-get::audio/wave:
http-get::audio/x-wav:
http-get::audio/x-m4a:
http-get::audio/x-flac:
rtsp-rtp-udp::audio/flac:
rtsp-rtp-udp::audio/x-dsf:
rtsp-rtp-udp::audio/ogg:
rtsp-rtp-udp::audio/x-dff:
rtsp-rtp-udp::audio/m4a:
rtsp-rtp-udp::audio/wav:
rtsp-rtp-udp::audio/aac:
rtsp-rtp-udp::audio/vorbis:
rtsp-rtp-udp::audio/x-aiff:
rtsp-rtp-udp::audio/aiff:
rtsp-rtp-udp::audio/wave:
rtsp-rtp-udp::audio/x-wav:
rtsp-rtp-udp::audio/x-m4a:
rtsp-rtp-udp::audio/x-flac:
DLNA 1.5: Yes
Gapless playback: Yes
Missing events workaround: No
Can play native DSD: Yes
16 virtual formats:
2 ch Non-mixable linear PCM Interleaved 8 little endian Signed Integer 22579.2kHz
0 physical formats
NrTracks: 0
MediaDuration: 0:00:00
CurrentURI:
CurrentURIMetadata:
nextURI:
nextURIMetadata:
PlayMedium: NONE
<?xml version="1.0"?> 1 0 SetAVTransportURI InstanceID in A_ARG_TYPE_InstanceID CurrentURI in AVTransportURI CurrentURIMetaData in AVTransportURIMetaData SetNextAVTransportURI InstanceID in A_ARG_TYPE_InstanceID NextURI in NextAVTransportURI NextURIMetaData in NextAVTransportURIMetaData GetMediaInfo InstanceID in A_ARG_TYPE_InstanceID NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetMediaInfo_Ext InstanceID in A_ARG_TYPE_InstanceID CurrentType out CurrentMediaCategory NrTracks out NumberOfTracks MediaDuration out CurrentMediaDuration CurrentURI out AVTransportURI CurrentURIMetaData out AVTransportURIMetaData NextURI out NextAVTransportURI NextURIMetaData out NextAVTransportURIMetaData PlayMedium out PlaybackStorageMedium RecordMedium out RecordStorageMedium WriteStatus out RecordMediumWriteStatus GetTransportInfo InstanceID in A_ARG_TYPE_InstanceID CurrentTransportState out TransportState CurrentTransportStatus out TransportStatus CurrentSpeed out TransportPlaySpeed GetCurrentTransportActions InstanceID in A_ARG_TYPE_InstanceID Actions out CurrentTransportActions GetPositionInfo InstanceID in A_ARG_TYPE_InstanceID Track out CurrentTrack TrackDuration out CurrentTrackDuration TrackMetaData out CurrentTrackMetaData TrackURI out CurrentTrackURI RelTime out RelativeTimePosition AbsTime out AbsoluteTimePosition RelCount out RelativeCounterPosition AbsCount out AbsoluteCounterPosition GetDeviceCapabilities InstanceID in A_ARG_TYPE_InstanceID PlayMedia out PossiblePlaybackStorageMedia RecMedia out PossibleRecordStorageMedia RecQualityModes out PossibleRecordQualityModes GetTransportSettings InstanceID in A_ARG_TYPE_InstanceID PlayMode out CurrentPlayMode RecQualityMode out CurrentRecordQualityMode Stop InstanceID in A_ARG_TYPE_InstanceID Play InstanceID in A_ARG_TYPE_InstanceID Speed in TransportPlaySpeed Pause InstanceID in A_ARG_TYPE_InstanceID Seek InstanceID in A_ARG_TYPE_InstanceID Unit in A_ARG_TYPE_SeekMode Target in A_ARG_TYPE_SeekTarget Next InstanceID in A_ARG_TYPE_InstanceID Previous InstanceID in A_ARG_TYPE_InstanceID X_DLNA_GetBytePositionInfo InstanceID in A_ARG_TYPE_InstanceID TrackSize out X_DLNA_CurrentTrackSize RelByte out X_DLNA_RelativeBytePosition AbsByte out X_DLNA_AbsoluteBytePosition SetPlayMode InstanceID in A_ARG_TYPE_InstanceID NewPlayMode in CurrentPlayMode TransportState string STOPPED PAUSED_PLAYBACK PAUSED_RECORDING PLAYING RECORDING TRANSITIONING NO_MEDIA_PRESENT TransportStatus string OK ERROR_OCCURRED CurrentMediaCategory string NO_MEDIA TRACK_AWARE TRACK_UNAWARE CurrentTransportActions string PlaybackStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD RecordStorageMedium string UNKNOWN DV MINI-DV VHS W-VHS S-VHS D-VHS VHSC VIDEO8 HI8 CD-ROM CD-DA CD-R CD-RW VIDEO-CD SACD MD-AUDIO MD-PICTURE DVD-ROM DVD-VIDEO DVD-R DVD+RW DVD-RW DVD-RAM DVD-AUDIO DAT LD HDD MICRO-MV NETWORK NONE NOT_IMPLEMENTED SD PC-CARD MMC CF BD MS HD_DVD PossiblePlaybackStorageMedia string NONE NETWORK PossibleRecordStorageMedia string CurrentPlayMode string NORMAL REPEAT_TRACK REPEAT_ONE REPEAT_ALL NORMAL TransportPlaySpeed string 1 1 RecordMediumWriteStatus string WRITABLE PROTECTED NOT_WRITABLE UNKNOWN NOT_IMPLEMENTED CurrentRecordQualityMode string 0:EP 1:LP 2:SP 0:BASIC 1:MEDIUM 2:HIGH NOT_IMPLEMENTED PossibleRecordQualityModes string NumberOfTracks ui4 0 512 CurrentTrack ui4 0 512 1 CurrentTrackDuration string CurrentMediaDuration string CurrentTrackMetaData string CurrentTrackURI string AVTransportURI string AVTransportURIMetaData string NextAVTransportURI string NextAVTransportURIMetaData string RelativeTimePosition string AbsoluteTimePosition string RelativeCounterPosition i4 AbsoluteCounterPosition i4 LastChange string A_ARG_TYPE_SeekMode string ABS_TIME REL_TIME TRACK_NR ABS_COUNT REL_COUNT X_DLNA_REL_BYTE A_ARG_TYPE_SeekTarget string A_ARG_TYPE_InstanceID ui4 X_DLNA_RelativeBytePosition string X_DLNA_AbsoluteBytePosition string X_DLNA_CurrentTrackSize stringCurrent device RootDevice description:
<?xml version="1.0"?> 1 0 QPlay:2.1 urn:schemas-upnp-org:device:MediaRenderer:1 LS50 Wireless II KEF http://www.kef.com/ LS50 Wireless II LS50 Wireless II SP4025 http://www.kef.com/ caa8aed0-beb0-424f-a441-593d522de097 uuid:ab707cf6-f37b-49a6-b8b2-e74c5b39100d image/png 120 120 24 /LibRygelRenderer-120x120x24.png image/png 48 48 24 /LibRygelRenderer-48x48x24.png image/jpeg 120 120 24 /LibRygelRenderer-120x120x24.jpg image/jpeg 48 48 24 /LibRygelRenderer-48x48x24.jpg urn:schemas-upnp-org:service:ConnectionManager:1 urn:upnp-org:serviceId:ConnectionManager /xml/ConnectionManager.xml /Control/LibRygelRenderer/RygelSinkConnectionManager /Event/LibRygelRenderer/RygelSinkConnectionManager urn:schemas-upnp-org:service:AVTransport:1 urn:upnp-org:serviceId:AVTransport /xml/AVTransport2.xml /Control/LibRygelRenderer/RygelAVTransport /Event/LibRygelRenderer/RygelAVTransport urn:schemas-upnp-org:service:RenderingControl:1 urn:upnp-org:serviceId:RenderingControl /xml/RenderingControl2.xml /Control/LibRygelRenderer/RygelRenderingControl /Event/LibRygelRenderer/RygelRenderingControl urn:schemas-tencent-com:service:QPlay:1 urn:tencent-com:serviceId:QPlay /xml/QPlayDescription.xml /Control/LibRygelRenderer/QPlay /Event/LibRygelRenderer/QPlay http://192.168.1.17:80/ DMR-1.51UPnP devices found : 8
Device #0: ID 0x0 Denon AVR-X3600H UID: uuid:c3481f2d-3578-18dd-0080-0005cdbcffda Location: http://192.168.1.10:60006/upnp/desc/aios_device/aios_device.xml
Device #1: ID 0x0 Zeppelin Air_006740 UID: uuid:5f9ec1b3-ed59-1900-4530-ec66d1006740 Location: http://192.168.1.5:8080/description.xml
Device #2: ID 0x0 LS50 Wireless II UID: uuid:ab707cf6-f37b-49a6-b8b2-e74c5b39100d Location: http://192.168.1.17:38111/ab707cf6-f37b-49a6-b8b2-e74c5b39100d.xml
Device #3: ID 0x0 ATOLL Streamer UID: uuid:059cf0b1-a2fb-4ee0-b483-c3eb8f8a2932 Location: http://192.168.1.4:60936/059cf0b1-a2fb-4ee0-b483-c3eb8f8a2932.xml
Device #4: ID 0x0 Denon AVR-X3600H UID: uuid:f843001d-2a34-1fda-0080-0005cdbcffda Location: http://192.168.1.10:60006/upnp/desc/aios_device/aios_device.xml
Device #5: ID 0x0 Denon AVR-X3600H UID: uuid:ddb5dabf-16f9-18db-0080-0005cdbcffda Location: http://192.168.1.10:60006/upnp/desc/aios_device/aios_device.xml
Device #6: ID 0x0 Denon AVR-X3600H UID: uuid:99490efc-f638-c085-6761-e50b176516f0 Location: http://192.168.1.10:60006/upnp/desc/aios_device/aios_device.xml
Device #7: ID 0x0 Denon AVR-X3600H UID: uuid:53638669-2a87-4ca9-6bfc-b17fadbee52e Location: http://192.168.1.10:60006/upnp/desc/aios_device/aios_device.xml
Device #0: ID 0x4d Haut-parleurs iMac Manufacturer: Apple Inc. Model UID: Speaker UID: BuiltInSpeakerDevice-
