Different Sorting for Different Smart Playlists?
Hi all,
Let’s say I wish to create two smart playlists, with one sorted by date added (Recently Added) and the other by last played time (Recently Played).
As far as I can tell, if I change the sorting in one smart playlist this carries over to all of the other smart playlists, which means what I’m trying to do above in fact can’t be done.
Could anyone tell me if I’m overlooking something? I could really use playlist-specific sorting.
OS: macos
I also would to see sorting criteria that could be set differently for each playlist. Not found a way to do it myself. I have a “most played” playlist. When setting it to to sort via “ playcount” also effects the local library track list etc, have to delete the sort key for play count when going back to local library tracks to get the view by album/track number…….
Would also like if we could set up a limited number of tracks in a smart playlist selected by a criteria. Ie for the “most played” smart playlist it would nice to limit the number of tracks to say 20 or 100 to get a “top 20 most played” or “top 100” etc etc
If you do find out how to do it chime back with the solution!
Sorry, couldn’t figure out any way forward with this problem. I’ve created a feature request here:
